lannes
Flight distance : 4465 ft
I think we are all missing the point
The OP's AC is faulty and should be returned, a mini should be able to fly further than 30m from the controller in a wi-fi dense environment, let alone in a country field with a phone turned on nearby.
We've all seen the video of MM's flying about cities and suburbs with many 2.4ghz wireless networks and not having many interference problems, the OP's experience with the MM is not standard.
Have you refreshed the firmware and upgraded to 0.400 in both the RC, AC and batteries ? If not use DJI Assistant 2 on the PC to do so
The transmission power of CE 2.4ghz is much higher than the 5.8ghz, so you would want to use this 2.4 ghz for range anyway
