Tom_A
Flight distance : 899951 ft
You can’t just go by motor direction, that can be wrong too if it is not set up correctly in Betaflight. There is a diagram that shows the direction the motors should be turning in Betaflight configurator. Yo need to verify they spin this way. You can set reversed if you like running the props opposite, but that also requires setting the rotation direction using BL Heli Suite. You also need to verify that the motors spin up in the correct order. Use the motors tab with props off to do this. The quad can also flip out like this if the flight controller has been rotated but not configured to account for the rotation. You would probably not ruined a set of props if you had followed the Joshua Bardwell guid to doing a maiden flight. |
