Is my MM still safe to fly ??
12Next >
3203 59 2020-1-7
JJB*
Flight distance : 12225059 ft
Hiya,
After reading few posts about loosing height and sometimes loss of their MM is am getting nervous....
Is my MM still safe to fly? Do i feel comfort to fly above water etc?  or fly some distance out....
After updated my MM i went out today for a 'test flight'.
Breezy day so good day to test its performance.
In P-GPS flying against the wind with 100% fwd stick - pitch down 29 degrees - speed 7.3 m/s (chart1)
In P-GPS flying with tail wind with 100% fwd stick - pitch down 4.9 degrees - speed 8.1 m/s (chart2)
Start flight - batt 91% - batt volts total 8.1 vdc.
End flight  - batt 12% - batt volts total 6.6 vdc.
With 22% batt level in Sport mode with full fwd - 12.6 m/s, not a single NotEnoughPower in the log.
Hope that DJI will find the answers why some MM loose height out of the blue!
cheers
JJB
2020-1-7
themich0r
Flight distance : 62526 ft
I did also a stress test yesterday with the new firmware. It ended in a lot of power failures and loss of height in the end.
The log shows a lot of power warnings (maybe due to cold weather conditions +2 Celcius). But I'm not good in reading logs.
Gladly this was a test and no flight over water...
https://www.phantomhelp.com/LogViewer/W3GXSWOIRFAMRM89CBX1/
2020-1-7
JJB*
themich0r Posted at 1-7 03:48
Hi,
At the end of your flight uncommanded height loss !  see chart .
Indeed many many low power warnings.
Quick pitch changes have impact on holding the height steady, looks like that low power has effect on the height stability.
Time for DJI to give some explanation!
cheers
JJB
2020-1-7
ALABAMA
Flight distance : 10442687 ft
Very good points!
2020-1-7
DowntownRDB
Flight distance : 1722 ft
JJB, your test results are encouraging.  I haven't had any unexpected height loss on any flights to date.  Hopefully, DJI can determine why some are having loss of height and many others are not.
2020-1-7
DAFlys
Flight distance : 95125112 ft
Having read a lot of lost MM reports I would certainly feel nervous flying in any wind at the moment.
2020-1-7
DrohnenWalti
Flight distance : 15945 ft
Switzerland
Just an input, based on other threads and personal experience:
Has the battery you were using be updated to the latest firmware? Remember only the battery that was in at the time of the Firmware update will be updated to the latest Firmware. The others you need to update separately, based on my experience.
2020-1-7
cK-mini
Indonesia
is it pure software problems or maybe human error?? should tie MM with strings then.. troublesome..
2020-1-7
Minnesota
JJB* Posted at 1-7 04:07
Hi,
It could be possible that when aggressively pitching forward, that the pressure below the craft drops (Venturi effect) influencing the internal baro sensor, causing the flight S/W to think the altitude has increased, causing it to reduce RPM, thus causing a real altitude drop.
2020-1-7
Spark_Pilot_XxXx
Flight distance : 67841 ft
I am also a bit afraid because of so many altitude Drops and crashes. However i never Had in my flight time a singe powerload reached warning ever. I saw a Video where a guy said that the issues are caused by the propellors.
2020-1-7
themich0r
cK-mini Posted at 1-7 04:30
This was all happening flying straight at 3-10 meters altitude in sports mode. I had to activily avoid ground contact bringing the drone back to normal height. It almost crashed into one molehill. Some blades are damaged and the MM got a nice dirt look
Didn't have this problems with the older firmware.
2020-1-7
Ice_2k
Flight distance : 1132575 ft
Romania
Did you see those errors during the flight or only afterwards in the log?
2020-1-7
themich0r
Ice_2k Posted at 1-7 04:47
I saw it during the flight, that's why brought it back at low altitude. But the drone instantly went down when the popups came. Otherwise no chance to react.
2020-1-7
themich0r
Dirty Bird Posted at 1-7 05:12
Are all of your batteries updated to the latest firmware?
I really don't know. I need to check it later. But I expect when theres is no warnings and the drone starts that it should just work with whatever firmware.
2020-1-7
speed_freakz
Flight distance : 569852 ft
Thailand
To be honest ending a flight at 12% battery is a bit risky. I mean you can certainly do it, but in case something goes wrong these are not good numbers to go with.
I almost always get my drone back at 40%, and that usually means not more than 200-300m in distance.
2020-1-7
themich0r
speed_freakz Posted at 1-7 05:25
The battery was still at 50-40%. The warning was ' Aircraft max power load reached. Decrease altitude and fly with caution. If this persists, land immediately (Code: 30168)'.
2020-1-7
RBI
Philippines
I suspect the quality differences of the individual battery cells have also an impact by height loss.
Maybe the power consumption of the ESC get limited by firmware in the event of a current drop in the battery to ensure that GPS, compass and transmitter have sufficient power.
2020-1-7
Montfrooij
Flight distance : 2560453 ft
Hope DJI will fix it.
2020-1-7
JJB*
Yes, you are right, but my last part of the test flight was close to home, just to be sure.
Normally i land with value > 20%
cheers
JJB
2020-1-7
CYLSTUDIO
Flight distance : 375046 ft
I'm going to wait until the next firmware update before I fly again, seems like there are a lot of issues with the 0400 firmware update.  A lot of altitude losing issues around the web / youtube.  DJI please give us an explanation what is happening.
2020-1-7
speed_freakz
Thailand
Hi,
Can you please point me where did you find low power warnings? by that do you mean battery cells were operating at 3.400v?
2020-1-7
rooller71
Flight distance : 688005 ft
Hungary
Hello friends! (Sorry for using bad English translator) Here's another case like this! I'm sad!      https://www.youtube.com/watch?v=8mdfqsl5rXc     I ordered MM. but I can cancel my order! What could be a problem with many MM ??
2020-1-7
rooller71
Hungary
Hello friends! (Sorry for using bad English translator) Here's another case like this! I'm sad!   https://www.youtube.com/watch?v=8mdfqsl5rXc&t=24s    I ordered MM. but I can cancel my order! What could be a problem with many MM ??
2020-1-7
rooller71
Hungary
Could it be a problem that extra batteries have not been updated !?
2020-1-7
George GR
Flight distance : 2990653 ft
Greece
i owned a mavic mini... but i sold it and i'm happy!
when dji fixes all the problems then i will think if i buy again!
2020-1-7
Bigplumbs
Flight distance : 620164 ft
DrohnenWalti Posted at 1-7 04:27
I agree about the Battery firmware. I had some height loss and then updated my other 2 batteries and it seems ok now
2020-1-7
hallmark007
Flight distance : 9827923 ft
I think it’s still safe to fly, I wonder if some with the problem can go back to previous FW and test this would clear up if New FW is the cause of this .
2020-1-7
Ice_2k
Romania
hallmark007 Posted at 1-7 07:25
One of the users reporting this just today was on .03
2020-1-7
JJB*
speed_freakz Posted at 1-7 06:17
Hiya,
You will find them in the CSV file.
And far above 3.4volts.
cheers
JJB
2020-1-7
hallmark007
Ice_2k Posted at 1-7 07:27
So that tells us new FW is not a problem.
2020-1-7
speed_freakz
Thailand
Not Enough power 690 times? whew
2020-1-7
TDZHDTV
Flight distance : 2068550 ft
Dirty Bird Posted at 1-7 05:45
It's been pointed out there is a quirk with the Fly app on battery firmware updates.  By default the app automatically enters the camera view when the drone connects.  Once inside the camera view battery update notices do not appear.  I discovered this last night & found two of my batteries had not been updated.  I had not flown with the mismatched firmware.
Disable the "Auto Enter Camera View" in the app settings & check your batteries.  You need to fully exit the app before connecting with another battery to check another pack.
How do you disable going to camera view? Cheers
2020-1-7
themich0r
Back to the batterie firmware. I had to update 2 of the batteries...
2020-1-7
Eka
Flight distance : 1293625 ft
Serbia
These problems were noticed since first minis launched back in october, so firmware is not an issue here, or better to say all firmwares have this issue. We should just keep pressing DJI to do something, or at least adress the problem for a start.
2020-1-7
themich0r
Dirty Bird Posted at 1-7 08:04
So when you experienced the altitude issue do you know which battery you were using?  Was it one of the ones running the older firmware?
Yes I was flying with an unupdated batterie. Need to wait for the weekend to test again with the updated batteries.
2020-1-7
InspektorGadjet
Flight distance : 439915 ft
I had all my batteries updated, everything reflashed with DJI Assistant 2 as suggested, performed calibrations in ideal situation, even IMU calibration performed after 30 min outside.
Drops happened but I could raise height, is all posted in one of my threads, more flight logs soon.
2020-1-7
The Saint
Flight distance : 5902228 ft
when you have 5 batteries and you don't intend to fly more than 1 or 2 hours, I'm no sure how it even makes sense to go below 50% from a recreational perspective.  especially while everything is new and getting sorted out and the lower you go the higher the risk.  is it really that much fun that you can't land and change the battery?   it might be a habit because I don't even let me gas tank get below a certain point but maybe that's because I rarely drive far and visiting the service station every couple of weeks is ok.
2020-1-7
m80116
Flight distance : 3264131 ft
Thank you folks for doing the good work you're doing, hopefully DJI will listen to this (an many other) complaint about the height loss.
2020-1-7
TDZHDTV
Dirty Bird Posted at 1-7 08:01
At the main screen click Profile then Settings.
Brilliant, thanks
2020-1-7
themich0r
Seems like DJI just ignoring this thread / problem
2020-1-9
12Next >
