Tactical Trvlr
Flight distance : 255407 ft
Geebax Posted at 1-10 19:52
Yes, it can be a problem with the gimbal, as the gimbal system is a servo system and if it is adjusted a bit too sensitive, then it can vibrate all by itself. But DJI have had this problem in the past and presumably gotten it right by now. But in any event, it is easy to tell, because if it is a gimbal sensitivity issue, the gimbal will usually vibrate when the aircraft is powered on but not actually flying. Sometimes you can hear it buzzing, but not always. Try powering it up, then try starting the motors and gently touch the camera to see if it is vibrating. also, check the rubber suspension for the camera to make sure it is working properly.
I think you nailed it. I took it out again today since it's the first opportunity with good weather. Shortly after taking off in "C" mode I got the error "Gimbal Motor Overload". I promptly landed recalibrated the gimbal and it seemed to be ok for a short time. I just got home and reviewed the footage and most of it is wobbly again. This is so disappointing. I've never crashed, landed hard, or done anything at all to cause this problem. I have treated this drone like a fragile baby, and this still happens. I'm pretty certain i'm going to return this drone tomorrow. I realize it's only 500$ but it should at least function as designed. |
