DJI Gamora
Hi, thank you for reaching out. We highly recommend you to use only an application that was recommended by DJI. We do not recommend using a 3rd party software since if this software might cause an issue, the unit warranty may be void. Also, the DJI Assistant 2 software only works on PC and it is not compatible when using a mobile phone. Hope this helps. Thank you for your understanding and support! |
