flight simulator network error 008_008
34121 21 2020-1-11
djiuser_AIqiePXK2QpL
Does anyone know how to fix flight simulator network error 008_008... I cant login juat errors.
2020-1-11
Hi there, sorry for the difficulties, please check the suggestions below:
1. Switch to another internet provider, eg. your 4G on the mobile, and if the download is already completed, it would only cost minor data.
2. If the issue is not fixed, perform the following steps: turn off the Simulator, reinstall the UE4PrereqSetup_x64.exe(default address: C:/Program Files(x86)/DJI Flight Simulator/UE4PrereqSetup_x64.exe).
3. For Windows computer, please install the Microsoft .NET Framework 3.5: https://www.microsoft.com/en-US/download/details.aspx?id=21
4. Restart the computer then launch the Simulator again, and check whether the issue persists.
2020-1-11
Henry92
Costa Rica
DJI Mindy Posted at 1-11 03:13
Hi! Still having same issue ** Network Error Error: 008_008 (000/0263) **. Follow all previous steps, nothing work.
1.Tried and change network (did not work), check and no network issues where found.
2.Already re-install the simulator. Did not work
3.Already download framework 3.5, did not work
4. Did restart and re-install simulator again. Did not work.
I'm doing it on a MacBook Pro, running Windows 10 on Parallels (VM). Version of simulator is the latest available, and is the free trial version. DJI Flight Simulator 2019-03-14 (2.2.0.0)
2020-1-12
djiuser_FhRZgvn0FSWD
No that did not help still get the 008_008 network error.
2020-1-12
djiuser_FhRZgvn0FSWD Posted at 1-12 18:50
Can anyone help to solve this network error 008_008 for the DJI Flight Simulator ?
2020-1-12
djiuser_zzEzCdJrI7KQ
Ukraine
"DJI Flight Simulator/UE4PrereqSetup_x64.exe"
Just run  Epic Games, Inc. UE4PrereqSetup_x64.exe SETUP before and the problem will be resolved
2020-2-20
toramanbaturgmail.com
Turkey
Finally! Unreal Engine solved the problem.
2020-4-15
djiuser_2ybZ0gnGctqk
Kuwait
Can I get a layman's terms of this thread,  I have the exact same issue.  Step by step.  Pleeeeeese. Thanks
2020-5-6
Kuwait
This was the part that I got lost,  is it possible to assist step by step?
2020-5-6
djiuser_DdkoGzyKjby5
Flight distance : 4629 ft
Go to the installation folder for the Flight Simulator (probably C:\Program Files (x86)\DJI Flight Simulator), find the program "UE4PrereqSetup_x64.exe" and run it. Follow any prompts to install any required dependencies (eg DotNet). Once this has completed you should be able to run the Flight Simulator.
2020-10-7
fans20995dd0
djiuser_DdkoGzyKjby5 Posted at 2020-10-7 15:52
I have a mavic pro 2 and I need a step by step to connect the controller so it's recognized by my mac. I'm running a dual boot system with Windows 10. The simulation software is running beautifully but isn't recognizing my controller. I'm hoping someone can help.
2021-1-20
fanse0d83b29
Flight distance : 370823 ft
Greece
i had the same problem, this works for me: https://forum.dji.com/forum.php? ... 969&pid=2022922
2021-1-30
fansf56c2360
Norway
DJI Mindy Posted at 2020-1-11 03:13
Hi.
Because of your excellent help before, I ask you about this too.
I have tried to run the DJI Simulator on a Mac Mini M1 throug Parallels.
I get as far as: Unreal Engine 4 Crash Reporter.
Coming up after hitting Start Button.
Any idea if my attempt is even possible..?
In forehand thank you for any help..
2021-4-15
ViolaDrone
United Arab Emirates
Tested in 2 PC same error , i installed everything  from every user said, with no luck
2021-5-17
Scorpion King
Flight distance : 269 ft
Already install net framework 3.5
But still same error
2021-11-1
Scorpion King Posted at 11-1 06:45
After installing Framework 3.5, please restart the computer then launch the simulator again, and check whether the issue is fixed. If not, please download the launcher on the official website after entirely uninstalling the software, and then download this: https://sim.djicdn.com/Product/D ... 9_03_13_17_55_01.7z and Unzip to the file path with the same name. Please change the save path (default path: D:\DFS) and make sure the disk space is sufficient.
2021-11-4
Rolandro
Just wanted to reply and say that the following advice from DJI Mindy worked for me on a Windows 11 system (not in a VM, just a bare metal Windows 11 installation):
"If the issue is not fixed, perform the following steps: turn off the Simulator, reinstall the UE4PrereqSetup_x64.exe(default address: C:/Program Files(x86)/DJI Flight Simulator/UE4PrereqSetup_x64.exe)"
Find where your installation is located for the application (right click the shortcut and open file location; if it puts you in your start menu directory, right click and open file location again within this directory for the application shortcut). Then run the application UE4PrereqSetup_x64.exe which is in this folder. This installs Unreal Engine 4 files onto your system which is what the DJI sim app runs off of. This same installer will also install the .NET 3.5 framework required if it doesn't detect it on your system. Afterwards, try running the DJI app again. This solved the issue for me. If it doesn't work for you after following these steps it may also be worth it to try restarting your computer after completing the installation to see if it needs to do so in order to complete the configuration.
2022-4-13
djiuser_YMAK34mhGivH
Portugal
DJI Mindy Posted at 2021-11-4 01:59
After installing Framework 3.5, please restart the computer then launch the simulator again, and check whether the issue is fixed. If not, please download the launcher on the official website after entirely uninstalling the software, and then download this: https://sim.djicdn.com/Product/DFS_Shop/Version1.4.0.0/DFS_Shop_BL_V1_4_X_X_DT2019_03_13_17_55_01.7z and Unzip to the file path with the same name. Please change the save path (default path: D:\DFS) and make sure the disk space is sufficient.
Hey, when i launch DJI Arena it crashes after 3 seconds. Can't seem to find a way to use this thing...
I've tried it all! Uninstall completely, install "UE4P...", uninstall "UE4P...", reboot, install ".net3.5", install DJI Flight Simulator on another disk...
What else can i do?
2022-5-22
Firley
Flight distance : 332526 ft
Switzerland
tried to install the UE4PrereqSetup_x64.exe and once started the Installation. And never got anymore than initialising. What is wrong?
2022-5-24
djiuser_YMAK34mhGivH Posted at 5-22 08:06
Hi there, may I ask if you're referring to the DJI Simulator? Is there any error message prompt up? Could you please provide us with a picture or video for our further confirmation?
2022-5-26
fans5d3e3440
Flight distance : 4964 ft
Getting the same 008_008 error.  Tried all combinations of uninstalling/reinstalling both the simulator itself and also U4PrereqSet with reboots in between each, but still always get the same error.
Also updated the firewall to allow all connections from DJI_FS.exe but still no joy.
Not sure I fully understand post #21 with regard to DFS_Shop_BL_V1_4_X_X_DT2019_03_13_17_55_01.7z.
2022-5-28
djiuser_C1lPl7uRYDY9
Flight distance : 198409 ft
This worked great, thank you!
2022-9-11
