Burak C.
Flight distance : 21814 ft
Turkey
davidms Posted at 1-12 06:26
Great video Burak nicely done. I think the key is to check all variables before take off (sat locks, wind speed, overall conditions etc) and if all is good then you’re good to fly. Doing so will significantly reduce the possibility of a fly away or drone loss. I realize there have been some mini malfunctions but I believe most “fly away” are pilot error.
I think you are quite right about that. Since I previously have multirotor experience, I know what to do and when. However since this was my first DJI drone, before flying I read a lot in this forum. Nearly every flyaway, every altitude drop I know what happened and learned lesson from other pilots mistakes. Since altitude drop was not pilot error, i did not fly above the water. Also I will not be flying before this problem was solved. First waited for >12 sats, then checked the wind. First flew couple meters high tested left right up down pitch yaw controls then I climbed around 50 meters or so tested there waited a little bit for more sats. Then I ascend to around 100 meters. Always checked the drone's altitude etc..
I think that was not so hard right? Better safe then sorry...
Thanks for the reply!
Cheers. |
