DJI Digital FPV System Release Notes (01/13/2020)
12Next >
15178 49 2020-1-13
DJI Support
Flight distance : 2408 ft
Overview:
  • Date: 2020.01.13
  • Air Unit Firmware: v01.00.03.00
  • Goggles Firmware: v01.00.03.00
  • Remote Controller Firmware: v01.00.03.00
  • DJI Assistant 2 (DJI FPV Series): v2.0.2
What’s New?
  • Added support for Air Unit (Lite).
  • Added on-screen display for remote controller signal strength.
  • Optimized custom on-screen display of goggles by updating center point icon.
  • Optimized settings for flight controller protocol. After setting the protocol between the air unit and flight controller, the air unit no longer needs to be restarted.
  • Optimized on-screen display of goggles in certain situations after customizing the on-screen display settings.
  • Fixed rare issue: public channel was displayed incorrectly after enabling custom on-screen display on goggles.
Notice:
  • Restart the air unit, goggles, and remote controller once the update is complete.
  • Make sure that the firmware of the air unit, the goggles and the remote controller are in the same version. Check the firmware version in Setting, Device Info, and then Device Info on goggles.
  • If the firmware update fails, restart the device and DJI Assistant 2 (DJI FPV Series), and try updating again.
  • Update the Air Unit (Lite) when there is good ventilation. Make sure that both the goggles and remote controller are powered off before updating the Air Unit (Lite). DO NOT touch the Air Unit (Lite) during update since the temperature rises. If update fails, wait for the Air Unit (Lite) to cool down and try to update again.
2020-1-13
djiuser_3wugiNxNqa9C
Romania
No updated OSD elements?  No iNAV support?  No fix to give back the range the original firmware had?  Any update on when some of those are going to be fixed?
2020-1-13
Montfrooij
Flight distance : 2560453 ft
Thanks for the update!
2020-1-13
djiuser_svTsi9rtdUUm
Austria
Caddx started shipping their airunit (vista) so they needed this update to get it to work. Hopefully there will be a major update at the beginning of februar :-) :-) :-D ?
2020-1-13
Bol2riz
Anything regading the radio controller?
Some sort of AUX configuration and channel mixing? Idle-up switch setting possibilities?
Simple Rx modules for LOS flying?
Thanks anyway for the update.
Best regards
2020-1-13
djiuser_90GiHJXBXaGU
Flight distance : 288707 ft
Power cycling the air unit now resets Custom OSD option in goggles.
2020-1-13
pRo_lama
Czechia
djiuser_90GiHJXBXaGU Posted at 1-13 11:53
Unfortunately, after this update, you will have to turn your goggles off after every battery.
2020-1-13
djiuser_jDnF3wAIDXS0
pRo_lama Posted at 1-13 22:43
no entendi....por que hay que apagar las gafas despues de cada bateria ?
2020-1-14
trojax
Flight distance : 896 ft
Hi I have just updated and now the custom OSD will not stay selected every power down reverts to NO CUSTOM OSD...
2020-1-15
TechnoCore
I can confirm, power cycling the air unit causes goggles to revert to Custom OSD = Off.
I'll likely be flying without custom OSD until this is fixed, too annoying to go through the goggle menu and re-enable every flight. I consider this a critical new bug.
The firmware seems otherwise excellent, the new controller signal strength is really nice to have for distance flights. The public channel bug is gone and so is the tiny lag spike that coincided.
Please fix the new custom OSD bug, and please add altitude, speed, distance to home, home arrow, and all warnings to custom OSD. Also please start recording custom OSD elements to srt.
2020-1-15
downset
If you plug off the goggles first and than the airunit, and for the next Battery first plug in the Air unit and than replug the googles, than the goggles will keep the custom OSD settings on.
It is still a bug but with this workaround its not so bad.
for me the most important updates would be:
-recording the custom osd to get the gps coordinates in case of crash
-more OSD options and the most important would be : Altitude, speed, homepoint direction and of cause the Betaflight warnings
when can we expect updates in this direction?
Greets
downset
2020-1-16
Yeclek
Flight distance : 109350 ft
I am also having the custom OSD issue. Every time I power cycle the Ait Unit the custom OSD reverts to Off.
2020-1-16
PeopleLookLikeAnts
+1 for betaflight warnings and home arrow in OSD. Please make it happen DJI!
2020-1-17
M_A_R_T_I_N
Me too.
@Dji: when you will release a Bugfix?
2020-1-18
pRo_lama
Czechia
M_A_R_T_I_N Posted at 1-18 13:47
Me too.
Already released v01.00.04.00
2020-1-19
downset
Perfect custom osd disappar is fixed - That was quick
and i like the Announcements for the next release, most likely the 01.00.5.00 :
OSD for Homeposition,  Altitude and Speed
But Nothing about warnings and also nothing about custom OSD Recordings... or is it ment with  Menu setting to choose to enable recording after unlocking the flight controller. Than it would be perfekt
And if I could add one more wisch witch i missed in last OSD wish Post: distance from home point
2020-1-19
Bol2riz
Not tested yet but thanks to the staff for the swift workaround.
2020-1-19
Austria
If i read correctly it just displays the hdmi input but can not show dji feed on a monitor.  :-( This would be great if you could show it to a friend just via cable. (We need this often also for our spotters) Spectator mode is useless because it doesn't have the same range.
This is also the reason why our local fpv club is not allowing races with digital and its the same for most of the clubs why they do not adopt Digital in races :-( :-( , but i hate racing in crappy analog :-( :-(
2020-1-19
gtbzz85
DJI.. please allow Audio to pass through the Air Unit and to the goggles!  That would make the FPV experience incredibly immersive!  Especially for those fixed wing pilots who could benefit from listening to the motor.  Thank you.
2020-1-22
kimib1
Poland
Any chance for live oudio feed in future release?
2020-1-23
TechnoCore
downset Posted at 1-19 05:14
and i like the Announcements for the next release, most likely the 01.00.5.00 : OSD for Homeposition,  Altitude and Speed
Where was this announcement on the next release made? Can you share a link?
They confirmed home position, altitude and speed??
2020-1-23
TechnoCore
For anyone else who was confused, they released .0400 but didn't announce it. In the release notes it said the following:
2020-1-23
RGMGFitness
Flight distance : 233757 ft
TechnoCore Posted at 1-23 12:39
[view_image]
BUMP....
DJI,
You should add this to the main FPV Forum section as a 'sticky'.  Its been over a week...not sure why your not announcing this firmware release in the forum as you've done with other releases?
Regards,
Ron
2020-1-24
downset
TechnoCore Posted at 1-23 12:25
It is also on the Downloadpage
https://www.dji.com/de/fpv/info#downloads
in the System Release notes is the full change log History and also the already shown announcement
2020-1-24
MacMen
Apart from me, someone else noticed the problem with audio / video drift in long videos recordet with the Air Unit? The Air Unit cuts Videos in 10 minute packs. So when you have a long flight (34 minutes) and play back the videos on a pc you will notice a drift from audio to video. They will not match at the end of the second 10 minute pack and this will be the same for the third and fourth.
2020-1-25
Tgoraj
I just looked up the DJI Smart controller.... $750.00 just to display my flight video? Ouch, no way this is going to happen for me. I wonder if it will also output to any HDMI monitor?
2020-2-5
fichek
Flight distance : 915233 ft
Croatia
MacMen Posted at 1-25 01:53
I haven't paid attention becasue removing sound is the first thing I do with any recording from a quad, but you're right, I notice the drift even in 4-5 minute clips.
2020-2-10
Alejandro8706
tienes razon espero que lo arreglen
2020-2-17
Alejandro8706
fichek Posted at 2-10 04:26
ojala lo arreglen pronto saludos
2020-2-17
djiuser_E9LGpbl5jyrR
Estáis trabajando en la latencia de la entrada Av?
2020-2-24
Hacky4
Czechia
Is it that hard to write in English?
Just image everyone wrote in their chosen language, would be great to understand in such discussion right? So don't be selfish and write in English even if it is not your native language.
2020-2-25
Alejandro8706
Hacky4 Posted at 2-25 01:12
hablo mi idioma nativo y punto....usa el traductor
2020-2-25
Hacky4
Czechia
Alejandro8706 Posted at 2-25 07:06
If you don't understand English, just use translator before posting here.
2020-2-25
Cobaki
Switzerland
This forum should really only allow submissions in English, are there no moderators?
2020-2-26
Alejandro8706
aqui puede estar gente de cualquier pais asi que es normal que hablen su idioma para eso estan los traductores ademas esto es dji en general no tiene por que ser solo en ingles.y dejo el tema que me parece tonto y de niños y no dire mas nada sobre el tema del idioma habla de otras cosas de drones.un saludo
2020-2-26
Hacky4
Czechia
Alejandro8706 Posted at 2-26 16:00
reported as spam
2020-2-26
Claro que sí
2020-2-27
Austria
I am also not native english (speak german) . It's selfish to speak in the native language. You could use google translator as well and post it in english.
2020-2-27
Alejandro8706
Hacky4 Publicado el 2-26 16:45
reportado como spam
jajajajaja ok ;) adios
2020-2-27
AndreFarinha
Flight distance : 2443064 ft
Portugal
hey guys, I still missing the audio... since you guys have in built audio on Air unit is it possible to enable while flying to improve pilot performance.
2020-3-24
12Next >
