DJI Stephen
Hello and good day RitZtoRubble. Thank you for reaching out and for the information. I hope that you will get the best recommendation from our valued DJI co pilots regarding this matter. Just a reminder that you can use the DJI Mavic Mini Charging Hub to store your DJI Mavic Mini Intelligent Flight Batteries. Just a reminder that the battery's performance will be influenced if it is kept idle for a long time. To maintain the battery's active state, it is recommended that users charge and discharge the battery every three months. Do not completely discharge the battery and then store it for a long time; otherwise, the battery will over-discharge and the battery cells will be damaged, which will make the battery unusable. In addition I will be posting a link where in you can see the manual of the DJI Mavic Mini Two-Way Charging Hub ( https://dl.djicdn.com/downloads/Mavic_Mini/Accessories/Mavic_Mini_Two-Way_Charging_Hub_User_Guide_v1.0_multi.pdf ). Thank you. |
