George210477
Flight distance : 2676129 ft
Romania
Choose carefully if footage needs D-LOG or Normal...D-Log is used mostly in good light, being more noisy, also you need to apply a Noise filter in lower light (of course, is no point in low light to use D-Log)...You can do this with Noise reduction from VR Noise reduction (free) from Premiere Pro, or with Neat Video Noise reduction and also RED Noise reduction (both very good but $$). Try to use Normal instead of D-LOG in low light, you can also fine tune the colors, even if you don't have the same control like D-Log or D-Cine profile...but in Normal mode is approx.twice less noise and you can also make some fine tune. Nice footage. Good luck! |
