simplesimon
Flight distance : 142841 ft
So I've done a few indoor flights without crashing (yet?).
And in my excitement, already forgot about some of the things I read in the manual about battery charging.
I got a low battery warning, landed the drone, and then almost immediately plugged the drone in to charge the battery, noticing the #4 LED successively blinking 3 times with a pause.
Back to the instructions I went, learning that the battery temperature was too high. Eventually it started to charge.
The instructions state, "If the charging temperature protection is enabled, the battery will resume charging once the temperature has returned within the allowable range".
Does the word "if" mean that I have control over whether or not this protection is enabled? I hope that's not the case. If I do have control, where is it?
Thanks for your help.
