JJB*
Flight distance : 12225059 ft
JeremyFr79 Posted at 1-20 13:38
Not sure I understand you saying it doesn't show end of flight? When I look at it in FRAP there's a disconnect at the end of the log which is when it hit the water. Am I missing something?
Hi Jeremy,
Last part of this flight, the actually crash in the water is not in the file. Got disconnected.
But flying at 0.9 meters above water in Sport mode, my guess is that your MM lost height beacuse of the rapid pitch changes you made.From 100% aft stick to 100% Up stick (not as you said "let go of the sicks"), picth angles from 27 degrees UP to 28 DOWN, it is not strange for a drone to loose some height during this manoeuvre.
But flying at 0.9 meters (VPS measure value) no free air anough to drop little and go up again. (normal behaviour).
It did drop but could not recover....
So IMO too much rapid input at low altitude causes this loss.
BTW if the connection was still there at the impact you would have seen high pitch and roll values, so i think that the actual moment of hitting thw water is not in the file.(as it was disconnected, guess due to combination of distance, too low, reflecting signals).
cheers
JJB
