Madperk
Flight distance : 650089 ft
First up your dimensions are wrong. A raw image should be 5464x3640 zoomed in that far will show some pixelation.
Second there is no reason to be shooting with the settings you are using. Lower your iso to 100 and reduce your shutter speed. you should try to use full f-stops. Fulls are 2.8, 4, 5.6, 8 and 11. Half stops or third stops should only be used if you can’t get the correct exposure setting adjusting iso and shutter speeds. it’s not that grainy for a zoomed in and cropped shot.
Third it’s shot in raw which meanings that you still need to develop the image with Lightroom or some other raw editing application. If you don't want to develope the image shoot in jpeg.
