Mavic Air Error Codes
6078 2 2020-1-20
Agama
Malawi
Hi
I was flying my Mavic Air and crash landed it, checked everything is fine but it has started showing these errors
1. Barometer Data Error
2. ESC Status Error
i have done the following
1. updated the CR firmware
2. Updated the Drone firmware
3. Reseted to factor settings the Drone
nothing is happening
my SN: 0K1CF7P3AG3UD3
please help what can i do to have it start flying again?
2020-1-20
DJI Paladin
Flight distance : 318 ft
Hi. I am sorry to know about the incident with your DJI Mavic Air. Since you have tried refreshing the drone using the DJI Assistant 2 and the issue still persists. The drone may have internal damages which is causing this issue. I would recommend for you to contact our DJI support team to start up a ticket for the said drone at ( https://www.dji.com/support?site=brandsite&from=nav ).  We have the professional team who would do their best to  assists you with regards to this matter. We hope to hear from you as soon as possible for a swift resolution. Please note that the repair cost will depend on the said warranty period of the drone otherwise, valid charges will apply. Thank you.
2020-1-20
arseoy
Turkey
I just got my Mavic Air, but I keep getting a “camera error code 4,” and no video image on the phone. Is this a lemon? Should I return it? Or is there some simple configuration issue I’m missing? I also had problems registering and updating firmware, but that was eventually settled after many attempts.
2020-1-30
