Francoisd
Flight distance : 66352 ft
Dirty Bird Posted at 1-20 04:57
I often use RTH to head back from a long flight. I don't usually let it come all the way back & land, though I do occasionally. I have never had RTH fail in at least two thousand flights. Make sure you wait for a good Home lock, set your RTH altitude appropriately, & be mindful of the wind speed/direction & you should be fine. Another nice thing about RTH is, while the bird flies home, you can adjust altitude, rotate the drone, & pan the camera up/down while the flight computer brings you back. This makes for a nice sort cable-cam of sorts so you can focus on capturing images or video while the bird handles the fliying.
Some insist RTH is only for emergencies. Frankly, that is bunk. If it isn't reliable what good is it in an emergency? RTH is just another flight mode for you to enjoy. It is a safety feature & a convenience.
Hi,
Are you sure that you can move the MM while flying back in RTH mode ? I've read somewhere on this forum (from a dji moderator) that the only thing you can do in RTH is to move the camera, a single move on the sticks would cancel the RTH. |
