MRKS
Geebax Posted at 1-21 21:00
It is all quite normal. Yes, you can still save pictures or movies on the SD card in the aircraft, even though you don't see the picture, because they are two seperate streams. And there are multiple radio channels in both directions, hence you can still contol the aircraft even though you see no picture. If you are flying near a city, this happens all the time, one of the channels may be experiencing interference, but not the others. You will see this less if you are out in the country. Try switching your phone to airplane mode.
Hello Geebax,
thanks for the hint. I will check whether that makes a difference when I get back home tonight. I will keep you posted.
Cheers,
Markus |
