Ronin S motor noise
1418 6 2020-1-21
Signo11
Flight distance : 38104 ft
The first model I had bought was defective (it didn't stabilize), this one that Dji sent me from the repair center the engines make noise, is this normal?
2020-1-21
DJI Thor
Flight distance : 13602 ft
I am sorry for the troubles that you encountered. If it is convenient, please kindly provide a video of the noise engines to check further. Look forward to hearing back from you.
2020-1-21
Signo11
DJI Thor Posted at 1-21 18:33
https://drive.google.com/folderview?id=1z-B4cnKyhImktF6KYDMPuWYxt0Dhc5EN
very similar to this: https://youtu.be/uwdHKHut45w
2020-1-22
DJI Thor
Signo11 Posted at 1-22 01:20
Hi Signo, thank you for getting back, after checking, it sounds like the motor current sound, it doesn't look like the second video, which may cause by the balancing issue.
For the motor current sound, it is normal that the Ronin-S makes subtle sounds when being turned on. This is the sound of the current made by the motor when keeping the gimbal stabilized.
It is recommended that you carry out the balancing of the product before use and then perform the autotune. Thank you for your understanding and support.
2020-1-22
Signo11
DJI Thor Posted at 1-22 18:40
In the video made with the mobile phone the noise is less heard because the microphone is weak.  For example, if I make a video with the mirrorless plus the rode microphone, you only hear noise of ronin s
2020-1-23
DJI Thor
Signo11 Posted at 1-23 01:35
Hi, sorry for the late reply. In this case, please make sure that the Ronin-S has been balanced properly, , and manage an auto-tune. See if the issue persists.
2020-1-25
Signo11
DJI Thor Posted at 1-25 19:51
It isn't a balancing problem, this noise does it even without any camera on it and also with the motors in stand by.. the noise comes from the pan axis
2020-1-26
