Change Quickshot dronie angle ?
3422 13 2020-1-22
philgib
Hello,
I am a real estate agent and dronies are a must
Being able to change the dronie distance is great but changing the height or angle would be extremely welcome
Thank you
2020-1-22
Dmitry Vishnevskiy
Flight distance : 588635 ft
Russia
The "dronie" can be easily done in manual mode. My Phantom doesn't have quickshots...
2020-1-22
DAFlys
+1 for a great idea.
2020-1-23
InspektorGadjet
Flight distance : 439915 ft
I came out with an idea for panoramas, where one could set an initial point A and and end point B and drone could "pan" between these two positions either taking video or pictures.
This could be also useful for what you suggest, start A, end B even with different gimbal angle, then drone could transition between these two points.
2020-1-23
Miixxa
Flight distance : 280682 ft
Finland
I'm not sure if it works with Mini cause I haven't tested it, but in other drones you can adjust the angle of the dronie by setting the drone starting point/height according to desired fly path of the dronie. F.e. bringing the starting point closer and/or higher the angle is greater etc...
I'd say it may work with the Mini too since those few dronies I've done the drone doesn't move after activating dronie, only yaw and gimbal adjustments are made to center the chosen target.
Can anyone confirm this? I can't test it before the weekend.
2020-1-23
Dmitry Vishnevskiy
Russia
DAFlys Posted at 1-23 01:15
In real estate movies i make "dronies" on 200-400 meters (with boost speed in postprocessing). Drones cant make that in quickshot mode.
2020-1-23
djiuser_bspCaGpYXt0P
Yes once you are good at piloting you do not need dronies quickshots.
But I am hiring new realtors all the time and they are not all Gods and Godesses in flying drones.
Quick shot dronies helps for that matter.
Some people are just "I push a button and voila" ;-)
2020-1-23
jonny007
Yes, you can take all quickshots manually, including boomerang and all rising or falling too, but it looks stupid when you see yourself with the remote control in the video. I think that is mainly the argument not to fly a quickshot manually, not to mention that it isn't easy (except rocket and dronie)
2020-1-23
DJI Paladin
Flight distance : 318 ft
Hi. Thank you for reaching out to DJI Forum. Thank you for your suggestion. I will forward this to our designated DJI support team for further attention. Thank you.
2020-1-23
DAFlys
djiuser_bspCaGpYXt0P Posted at 1-23 07:21
But if you're doing this for business they would need to be trained and pass an exam to allow for commercial usage.
2020-1-24
DAFlys Posted at 1-24 00:31
The European law is changing in July 2020,
unrestricting the biz use of a sub-250g drone   . Well that was the plan before Covid-19.
2020-4-6
DAFlys
djiuser_bspCaGpYXt0P Posted at 4-6 13:57
Are you sure that's the case,  Ive not seen anything about removing restrictions for commercial use.
2020-4-7
Golfingmoron
Flight distance : 70991 ft
DJI Paladin Posted at 2020-1-23 09:15
Any chance of a software update so the Dronie's angle can be changed.  For me, it was too shallow for a recent project.
2021-12-24
Guorium
Flight distance : 513061 ft
Just do manual dronie. Auto dronie tries to lock the house in the centre of the frame. You cannot change that.
2021-12-24
