jdzac
I have a six-month old P4-RTK with about 20 flights on a particular battery, so lots of life left in it. Right after takeoff the other day, I got a message on the RTK controller that said "Battery is damaged", with all sorts of red flashes. I envisioned my investment falling out of the sky, but I was able to land it - immediately - with no issues. Examined the battery, looked good, reinstalled and checked connections, and took off again; this time no higher than six feet. After five seconds, same "Battery is damaged" message. Removed battery, looked at the Airdata record, which I've attached here (file name ends in 012020). So I figured my smart battery was now just an expensive paper weight. But Airdata also told me that it was time for a basic service on that battery, which is just a deep cycle (deplete to 8%, then recharge). So I deep cycled it, then took the risk of CAUTIOUSLY flying it again for a few minutes. Worked fine, and wasn't hot, so flew it until 28%, then brought it in and looked at the Airdata record again. All cells are perfectly aligned, as shown in the second attached file (file name ends in 012320). So all that just to say that if you get a "Battery damaged" warning, with really ugly current deviations, it may not be the total loss that you think. Try deep cycling it, and see what happens. But you may want to keep a close eye on it.....
