dmiles
Flight distance : 455312 ft
Did you calibrate your transmitter by itself using the DJI RC system assistant? I believe you would calibrate the lever on back as well using that software, with the transmitter connected via the usb port. Then I would calibrate everything using the phantom 2 assistant. Pay attention to how the lever in the back calibrates. It should move smoothly back and forth. I had that type of transmitter, and I never could get that lever to work right. I've heard others have had the same problem. Good luck. |
