Ice_2k
Flight distance : 1132575 ft
Romania
MB Dronie Posted at 1-26 16:40
Thank you for your help. Well the color issue is the most annoying really. I found a similiar issue from other person which had snow white color in the left and in the right color changed to light blue. This is the same issue I am facing with the water color in my video, so we must wait from some upgrade to our firmware from DJI to solve this.
Once again, thank you for taking the time to answer me.
I am the other person but I don't think it's the same issue. In my video the camera was almost stationery and yet the color of the snow was shifting because the Mini decided to change it's WB at that point. In your movie I don't really see any color shift, it's pretty consistent as you're panning. Also, it's not really accurate to say that the color is different "in reality" as you're not looking at it from a few hundred feet up in the air, the light is probably hitting the water at completely different angles from that perspective.
As for the 2nd part of your question, Dirty Bird is pretty much right. When letting go of the stick in S mode, the drone will tilt backwards to brake as fast as possible. This probably means tilting backwards to about 30 degrees. It's not physically possible for the gimbal to go down that much to still be looking straight down at the ground. Furthermore, it doesn't really matter if you ask me. Any footage where you're going flat out and then instantly stop is not great footage anyway, you need to be smooth in your movements. Just release the stick gradually and it'll be fine. |
