Mark The Droner
Flight distance : 2917 ft
That gizmo is what DJI calls a "range extender" because it extends the range of your wifi-enabled mobile device. It acts as a bridge for the two-way communication system between your drone and your mobile device and allows for the FPV and telemetry display on your flight app. It has nothing to do with the flight control system of your drone. To make use of it, you will need a mobile device, the DJI Vision flight app installed on it, and then you'll need to bind the bird-side wifi signal (if there is one) to your RE and mobile device. Finally, you'll need to clasp your hands together and say a little prayer in hopes that the NAND chip within the wifi module still works correctly, which ain't likely. Good luck. |
