Can you adjust trim on controller?
8379 5 2020-1-27
fansb2ae3dba
Is there a way to adjust stick trim on the fpv remote controller. I've got the DJI FPV equiped IFlight Bumblebee and it drifts pretty hard to the right when the right stick is centered. Is it a betaflight thing, if so how? I can't figure it out.
Thanks!
2020-1-27
Bol2riz
Hi,
Yes you can, I did struggle on this too.
(Make sure to have properly calibrate your radio first, your issue may be related to that)
To adjust your endpoints and trim axes you've got to turn your Air Unit, your quad and obviously your radio ON.
Once everything is linked you've got to long clic on the right rotative button of the radio. In the google you'll see the configuration screen of the radio.
Go to "sub-trim" click on the field you want to adjust and you should be good to go.
Have a good flight.
2020-1-28
fansb2ae3dba
Bol2riz Posted at 1-28 01:48
Hi,
That was it!!! Thanks!
2020-1-28
Tom_A
Flight distance : 899951 ft
Not necessarily the best way to adjust this. You want to adjust the sub trim values to center the channels at 1500 and you should calibrate the gyro in Betaflight. Otherwise, you can get some unexpected behavior if you try acro mode.
2020-1-31
djiuser_zShgQy2omf1N
How to trim in-flight?
I use it on a plane and need to trim the elevator. Using the menu I loose the image. Is there any way to trim in-flight while still looking at the video?
2021-10-27
fans815b2bff
This worked for me. Thanks.
2022-11-30
