120ccpm
Flight distance : 1396755 ft
Ice_2k Posted at 1-28 01:08
I think a much more realistic possibility is for them to add the failsafe options the GO4 app have, meaning you would be able to tell the Mini to simply hover in place once signal is lost instead of trying to RTH.
Traceback without GPS seems rather difficult, not sure if any DJI drone has that capability.
Having the option to hover in place when signal is lost seems an easier and more realistic option, especially in situations where you are not far from the AC and can hopefully change position until you regain signal. In the particular scenario envisioned by the OP (flying inside abandoned buildings), I personally would not want the MM to try and land when it loses signal, as I think the risk of hitting something would be quite high. Better stay where it is, and let the pilot get closer and back in control. If that doesn't happen, then of course land. |
