Miixxa
Flight distance : 280682 ft
Finland
Christian U Posted at 1-30 23:38
If you can tell me an Fact based Reason, ill do.
1. This is an brand new Drone directly from Package that has surely been tested in the Factory. I cannot imagine that the props should have Problems by factory.
Okay:
1. Some MM's have had defective props from the factory, or more specifically props have been warped in transit because of the way DJI packs them, especially in Fly More Combo. There's no real factual explanation BUT it's a fact that some users have had bad props straight out of the box. Myself included.
2. Like I said, I had bad props straight from the box. I didn't even notice it on the first few flights until these drops (and some other issues) started to happen. I inspected the props thoroughly and discovered one single blade to be warped an more flexible than others. Caused random erratic flying, drops and clattering sound and didn't happen consistently. Since I changed the props (or that one pair of blades on the motor that had the warped one) I haven't noticed anything as bad as I had first.
(But yes, there are lots of stuff in the firmware that DJI needs to fix, not denying that!)
Of course these are not DJI confirmed facts rather than empiric data and similar occurrences from forums etc.
Changing the props in your case would eliminate one of the most common faults and help the troubleshooting.
It's also the easiest and cheapest way to maybe fix, or atleast improve the flying characteristics of your MM... |
