hallmark007
Flight distance : 9827923 ft
JJB* Posted at 2-2 03:14
Well... its the same for the go 4 app.
Never Never is the height changed in logs or dat files when craft flying over a lower part, ofcourse it goes into minus values flying below HP height,but never is the measured height in logs reset etc in that situation.
I’ll tell why, first I never mentioned what was recorded in the logs, secondly just over two weeks ago I commented on a thread to explain how a craft could pick up interference on the ground that could later in the flight affect how craft reacts, flight was just over one minute long, on the same thread you posted to me that you didn’t believe this could happen, but low and behold your on a thread a couple of days ago almost verbatim saying that interference on the ground was as a direct cause of craft going rogue well into flight, you say when you wrong you apologize this is completely wrong and many times you have been proven completely wrong where you refused to back down and apologize .
You are continually condescending to others who don’t agree with you, to the point that they have no choice but to react.
Posting enough graphs to wallpaper a small house doesn’t mean you know everything if you can’t interpret what is going on in those logs it’s fruitless and arguing that you do is even more fruitless, I also along with member gimpy pulled you up on a log that you interpreted completely wrong and for almost two days you argued you were right but you were completely wrong, but no apology came, so don’t be all high and mighty because truth is you don’t or won’t admit your wrong.
You put that post in this morning, but instead of posting to me you did your usual snake in grass thing , you need to grow a pair and instead of running crying to others accept the reasons why people are annoyed.
One thing I will say to you, as long as I’ve been around here I have never once seen any of your log readings used to help anyone gain a warranty or change a decision by dji.
But I can say that I have seen Labroids on several occasions help others to gain warranty and also to get dji to change their decision on other cases, and that’s because he can interpret logs he doesn’t need to post 10 charts that 95% of people don’t understand he can interpret a log that both beginner and experienced pilots can understand.
So I won’t be referring to post 134, but I still believe you to be a snake . |
