120ccpm
Flight distance : 1396755 ft
Ice_2k Posted at 2-1 04:06
The MM has a certain top speed for each mode. That is *air* speed. For instance in P-mode it will fly at 18mph. If there’s strong head wind (say 20mph) the MM will actually fly backwards at 2mph. It will not increase its air speed to make forward gains, even though it’s technically capable of doing it. The same is true with respect to maintaining position. If the wind is higher than its top speed in the current mode, the Mini would basically have to fly faster than that top speed just to maintain position, which it won't do. So in conclusion, yes, I think it's perfectly normal to see the Mini maintain position easier in S mode.
I would not be so sure, actually. DJI drones don't have a way to measure airspeed, only groundspeed via GPS. If you look at the specs, DJI states that in P-Mode the MM has a "Max Speed" of 8m/s and a "Max Tilt Angle" of 20 degrees. When I first looked into it, I thought it meant that at full stick the AC would tilt 20 degrees, and on a calm day that would translate to a top speed of approximately 8m/s. I don't think that's the case. Actually, I'm sure it isn't: my MM in P-Mode at full stick, on a calm day, reaches 8m/s at about 15 degrees. Why is it not using the extra 5 degrees? I'm thinking that those 8m/s are actually a max allowed (i.e. limited) groundspeed, for that mode.
It would be fairly easy to prove: on a day with a gentle breeze, try flying up and down wind. With headwind, will the AC use those extra 5 degrees to try to reach 8m/s? And in case of tailwind, will it slow down (decrease tilt) not to exceed 8m/s?
On another thread, Dirty Bird said that for some DJI drones you can set RTH max speed and max tilt (sort of a hack, but possible). He also said that the AC does not exceed the set max speed, even in case of tailwind, which seems to confirm that "max speed" should really be read as "max allowed groundspeed".
I think we can only guess how the MM behaves in various modes, but we cannot know for sure how DJI programmed it. I looked at a recent flyaway log (on this forum) where RTH was engaged and - apparently - the AC encountered some headwind: groundspeed was well below 8m/s and tilt was mainly between 15 and 20 degrees, but it was not constantly near 20 degrees, which is what one would expect if the AC was programmed to try to reach the set max speed, within the limit of the max tilt angle.
