Mavic Mini just free falling from 90ft
123Next >
6332 85 2020-2-1
GavinThin
Flight distance : 37736 ft
Malaysia
Hi everyone in DJI community,
I am new here so to say hi to everyone.
I just nearly got an heart attack when my DJI mavic mini just free falling from almost 100 ft within seconds and landed on a concrete ground.
Situation was that I trying to capture some night image with very very far distance fireworks.
Didn't really hover my MM around , but to keep it close and right on top of homepoint. And really lucky I did so.
Was somehow ok on the first few minutes but not sure what happen on the 9-10mins mark that it just dropping in altitude and suddenly "stopped" i assume and free falling.
I suspect that it might have something to do with the downward sensor , not sure if it's due to the darkness of the environment so it can't detect the ground level ?
but actually there were streets lights.
Here's the flight log :
https://www.phantomhelp.com/logviewer/4JPL1CX70UIB01HYLR6Q/#
Would be glad if anyone could comment a little on these as I am really a beginner to drones.
Thank you in advance.
2020-2-1
hallmark007
Flight distance : 9827923 ft
Can you tell us what temperature you were flying at ?
2020-2-1
DJI Stephen
Hello and good day GavinThin. I am sorry to read and to know what happened to your previous flight with your DJI Mavic Mini. Since this unfortunate incident happened. Kindly please contact out DJI Support Team for further assistance at https://www.dji.com/support?site=brandsite&from=nav. We would do their best to find out the reason of the incident and then the corresponding resolution would be provided. Again I am sorry for what happened and thank you for your understanding.
2020-2-1
hallmark007
Hi Gavinthin, your log reads exactly as you say, but still a mystery and not a really good one, flying at night should be ok , just two things might cause problems, fog and cold, we have seen some similar landing in temperatures of 0 to minus 2 C, it seems the IMU in mini doesn’t like the cold, but other than that you might have a problem that needs to be sent for repair or replacement by dji.
Maybe some testing at lower altitude in both day and night time .
2020-2-1
m80116
Flight distance : 3264131 ft
Your battery was pretty low when the AC stalled after more than 2000 ESC NotEnoughPower errors.
I think you may have:
- bad/bent out of shape propellers.
- ESC problems
- battery problems, battery chip version mismatching with AC firmware revision.
2020-2-1
InspektorGadjet
Flight distance : 439915 ft
hallmark007 Posted at 2-1 10:48
Hi hallmark007!
Is true that quite a few drops have been cold related, however all of my drops happened between 8 and 14 degrees + Celsius.
I don't think is just one thing but could be a combination of IMU readings, a bit less power in the motors, extreme or demanding movements in sports mode, wind, altitude...
I strongly believe we will see an improvement in the next FW update.
2020-2-1
SveinDJI
Flight distance : 1273379 ft
Norway
I've also had problems with MM losing altitude, but its just from 2-4m over ground and not like freefall. And it stops if i give full throttle. DJI says it could be the cold, been flying in -10 to -2 celsius.
2020-2-1
hallmark007
InspektorGadjet Posted at 2-1 12:10
Hi hallmark007!
I’m not sure what it is, I don’t have a problem with it, but in testing in cold conditions I can create this with mini .
I ask the question to confirm or eliminate and I asked OP to test also to eliminate.
2020-2-1
Oracle Miata
Flight distance : 3759829 ft
The mini can be unpredictable in cold weather.  I've seen it fly terribly, but I have also seen it fly normally in quite cold temps.
2020-2-1
Zelmani
Flight distance : 1555833 ft
Neither temperature nor wind seem to be the cause here:
2020-2-1
hallmark007
Zelmani Posted at 2-1 15:08
[view_image]
I wonder humid would that cause sensors to fog up ?
2020-2-1
Tervist
Flight distance : 20830 ft
hallmark007 Posted at 2-1 10:20
The OP is from Malaysia, so I don't think cold weather would have been a factor.
2020-2-1
hallmark007
Tervist Posted at 2-1 15:31
Yeah I see that from post above, I did also ask if there was fog but not that either but it was extremely humid so would this cause sensors to fog up and force craft to land, I don’t know just being devil’s advocate here .
2020-2-1
GavinThin
Hi hallmark007, Thanks for the reply and concern.
I am guessing about 28 - 30 degree ?
Wasn't a cold place on my side.
2020-2-1
GavinThin
Malaysia
DJI Stephen Posted at 2-1 10:23
Hi DJI Stephen, Thanks for the reply and concern.
Yes, will do as suggested.
I updated my firmware everytime before my flight and this is the only time this happen.
Updated firmware of the version at 1st of Feb 2020.
2020-2-1
GavinThin
Malaysia
Hi hallmark007, thanks again for the prediction.
My place wasn't a cold place and don't think there's any fog around at that time.
So I think it might be caused by other reason.
sadly.
2020-2-1
GavinThin
Malaysia
m80116 Posted at 2-1 11:24
Hi m80116, Thanks for the reply and concern.
I have experience previously return my drones at power level of 12-15% .
not sure if this time it just free falling at the battery level of 20-25%. seems not right.
Regarding the propellers shape, they are in good condition before take off.
but some of them have minor cracks after the drop. =(
What is an ESC problem ?
And how do i solve this battery chip problem ?
As I do update firmware before take off.
2020-2-1
GavinThin
Malaysia
Hi hallmark007!
Hi InspektorGadjet, Thanks for the reply and concern.
I am not sure about if these arethe causes as well,
but I just keep my drone on top of me, while rotating left and right.
doesn't windy as well...
Things that I did before the flight was update the firmware..
2020-2-1
GavinThin
Malaysia
[view_image]
Hi Zelmani, Thanks for the information.
How do you get these information?
From the link of my flight log able to extract these?
Sorry I am still a beginner.
2020-2-1
GavinThin
Malaysia
Hi Tervist,
Yes I am flying my drone in Malaysia.
So it's not a cold place definately.
Sky are clear and doesn't really have fog from what I see.
2020-2-1
GavinThin
Malaysia
hallmark007 Posted at 2-1 15:39
Hi hallmark007, Thanks for following my cases.
I not sure if my place is humid, doesn't rain for days.
Temperature was around 25-30 degree Celsius.
I am assuming as well that something wrong with the down sensor and force it to stop and free falling.
Not sure what type of sensor it's using, whether by light intensity or infrared to detect the distant.
Really scare ... out of me to have the drone just fall like that.
luckily i didn't fly my drone far from me.
2020-2-1
The Saint
Flight distance : 5902228 ft
fog and cold yeah, oh you mean Malaysia City which is a suburb of San Francisco?
If this drone cannot tolerate any other weather conditions outside San Diego, I know it's January all over but c'mon, is that the only place DJI tested (if they field tested this drone at all)?
2020-2-1
GaryDoug
Flight distance : 1264639 ft
I'm just a beginner here, but in the interest of educating myself, I took a look at the verbose csv data file created by phantomhelp using Excel. I compared it with one created for my drone while landing to see what differences I could find. It appears that the OP's drone was in "Go Home" mode at about 20% of the way through the flight if I am reading the file right; and then went into something called "Drop landing" mode about 25% of the way through the flight and stays that way for the rest of the flight. Does any of this make sense to the experienced users here? Just trying to learn.
Is it possible that the drone entered RTH mode somehow and did not show a notification? Then the operator used controls that interrupted the RTH mode including raising it to 90 feet altitude, then stopped using any controls and the drone resumed RTH mode and crashed because of the low light or fogged sensor(s)? Again, just a wild uneducated guess.
2020-2-1
Christian U
Flight distance : 189659 ft
I can reproduce this issue with flying at 6° 12min in sport mode.
What if we have this issue all in summer with flying 5mins at 25°?
Edit: i had never ESC Errors, so i think its an different issue.
2020-2-1
JJB*
Flight distance : 12225059 ft
GaryDoug Posted at 2-1 19:54
Hi Gary,
Great to have interest in logs.
User pressed RTH but because craft was within 20 meters from HP is did an autolanding.
So it was never in a GoHome mode, "DropLanding" means users did cancel the autolanding, as "DropGoHome" (btw: not in this file) means user cancel the RTH mode.
cheers
JJB
2020-2-2
hallmark007
Thanks Gavin, at least we have eliminated most of what I asked, my advice is to first sync your flight, try contacting a moderator here to ask if they can get an engineer to look at your log, in the meantime do some checks there are some other cases here and while some are common to the cold weather there seems to be no common denominator for all unless a bug in FW, I myself have had no noticeable problems .
It has also been recommended that you be on latest FW and calibrate IMU and gimbal .
2020-2-2
Zelmani
GavinThin Posted at 2-1 18:55
I downloaded your flight log from Phantomhelp and uploaded it to airdata.com. You can open a free account at their site to upload your flight logs. With the free account, you get basic information on errors during flight, signal quality and ground weather condition. With a paid account, you will have additional information, e.g. on winds during flight and battery statistics.
I have one question: Did you eventually have the propguards mounted when the drop occurred?
2020-2-2
GavinThin
Malaysia
The Saint Posted at 2-1 19:17
Hi, The Saint.
I am not sure which place you talking about but it happened in Malaysia.
Which is not cold at all.
2020-2-2
GavinThin
Malaysia
Hi GaryDoug,
Thanks for the analysis and detailed explanation. I am not sure if that's the problem as well.
I have submitted to DJI support and hopefully they manage to find a solution for this.
I myself are doubting might be the updated firmware.
And It's my first night flight. So I not sure if it's night flight as well...
2020-2-2
GavinThin
Malaysia
Christian U Posted at 2-1 22:25
Hi Christian U, Thanks for the reply.
However I am not flying in sport mode, but in tripod mode.
And I didn't also hover my drone a lot, basically it just raise up, rotate around to take some photo.
And drop.
2020-2-2
GavinThin
Malaysia
hallmark007 Posted at 2-2 03:13
Thanks hallmark007,
Yes I did submitted my case to DJI support. Hopefully they manage to come out with something.
I did also updated to latest FW and also did the calibrate process before take off.
2020-2-2
hallmark007
GavinThin Posted at 2-2 05:27
Thanks hallmark007,
Good luck GavinThin .
2020-2-2
GavinThin
Malaysia
Zelmani Posted at 2-2 04:26
Thanks Zelmani,
That's very useful information.
Yes, since I am still a beginner. I do wish to protect my propeller and hopefully I didn't crash my drones in few early flight.
So I do have the proguards mounted.
2020-2-2
GavinThin
Malaysia
hallmark007 Posted at 2-2 05:29
Thank you.
I will update here if there's any new information regarding this.
Do not wanted this to happen to another other drone owner.
2020-2-2
davidms
Flight distance : 428186 ft
GavinThin Posted at 2-2 05:29
Thanks Zelmani,
Did you have payload mode enabled?
2020-2-2
GavinThin
Malaysia
davidms Posted at 2-2 05:49
Hi Davidms,  Thanks for reply.
Sorry, I am still very new to this.
Does the payload mode you mentioned is the maximum altitude and distance restriction ?
I did see a maximum altitude range.
And when I raise my drone , I have reach my maximum altitude level.
But later I lower its altitude before the drop.
Does this affect the flying experience?
2020-2-2
davidms
GavinThin Posted at 2-2 05:58
While using prop guards you have to enable payload mode otherwise the drone does not have enough force to maintain a proper hover.
2020-2-2
JJB*
Hi Gavin,
If you reach at low altitude your max height , mayby flying in OPTI mode?
OPTI is activated when # GPS satellites are low or bad reception and there is enough light to fly.
If you like upload your flightlog (in wich this happens) using this link > https://www.phantomhelp.com/LogViewer/Upload/
cheers
JJB
2020-2-2
GavinThin
Malaysia
davidms Posted at 2-2 06:00
Hi Davidms,
Noted. From my few previous flight experience it just hover smoothly without a huge problem.
I will double check on this option again.
2020-2-2
GavinThin
Malaysia
JJB* Posted at 2-2 06:03
Hi Gavin,
Hi JJB, Thanks for the reply.
I think if it's automatically activated then I might be.
it's my first night flight. I am flying my drone outdoor, GPS should be working nice.
I did upload a flightlog and posted earlier
here's it again ::
2020-2-2
123Next >
