Bussty
Flight distance : 320951 ft
New Zealand
b_hirsch_photo Posted at 2-6 02:27
Hello , I am in the same situation, a photographer with his first drone & tons to learn:-) so far it is a lot of fun , but I struggle with the video editing part (beyond the DJI phone app). I think I will start as well with DaVinci , as i understand that 2.7 k export is free (opposite to 4k). But this world of frame rates, mixing mini & osmo pocket , 2,7 vs 4 K... all still very much a mystery to me .
What is your experience with resolve , any tips & tricks ???
Lol you and I look to be at pretty much the same spot on this journey. You are doing really well for a first video and if that is coming out of the DJI app...wow! Love how you included stills, that's a great idea as the Mini takes great stills too.
Best advice with Davinci is to watch a couple of beginner videos and just dive in! Trial and Error a great teacher :-) I found most of my compiling was in the CUT page which allows you to really precisely line things up. Here's some notes I keep in Evernote if it helps (still learning!)
Good luck and really enjoyed your video :-)
KEY STUFF
Shortcuts
* I = in O = out
* Ctrl F full screen video play back
* Shift Z toggle full timeline view
* N snapping
* J K L reverse stop forward
* M marker
* CTRL + SHIFT + Left Drag to shuffle clip in CUT page
* ALT + MOUSE SCROLL (CUT PAGE and on timeline strip in EDIT page) Scrolls Timeline
* ALT + MOUSE SCROLL (EDIT page on a clip) Stretches or Shrinks Timeline
* CTRL + S Save project
Arranging Clips
* Arrange clips in CUT page
* Select multiple cuts from video files
* Add in out clips using icons
* Ripple Override replaces clips removing gaps
* Insert clip between two clips either CUT page use SMART INSERT icon or EDIT page drag to timeline and select INSERT icon that pops up.
Edits
* Use left mouse scroll to fine tune cuts
* In CUT page use double arrows to jump to next transition
* Cross Dissolves must have enough "handle" or footage
* Fade to black using clip handles in EDIT page
* Reverse Clip - EDIT page - Right clip clip in timeline - Select Retime Controls - Bottom drop down box select Reverse
* Change Clip Speed - EDIT page - Right clip clip in timeline - Select Retime Controls - Bottom drop down box select speed required.
* Stabilize - CUT page - Tool option below Timeline window - Make sure clip selected - Select CAMERA - Stabilize
* Left Timeline Lock Track and Auto Enable
* ••• show audio wave form
* Audio Alt Click to add key frames to audio track
* Copy to other clips EDIT page right click copy the paste attributes Colour Correction
* Add Black - Tools / Generator / Solid Colour EDIT page
* Add Text - Tools / Titles / Text EDIT page
* WARNING small double arrows in box on left of timeline turns jump to next edit on and off
* Separate audio from video clink the link icon in EDIT page
* TRANSFORM / CROP / DYNAMIC ZOOM / ANNOTATE use EDIT page. Click on clip select option from small rectangle at bottom left of timeline window.
Audio
* To show waveforms select in options in top left of Timeline in EDIT page
Colour Grading
* Choose Color TAB
* Colour Wheels (Third Tool)
* Adjust Highlights / Middle Tones / Shadows
* Using Color wheels 1st (Primary Wheels) and 3rd (Log) Options.
* Measure in Scopes Waveform Monitor
* Targeted Saturation
* Choose Curves and third option Hue Vs Sat
* Select the first tool (Curves)
* Select color on video you want to saturate/desaturate
* Adjust up or down in Hue Vs Sat Graph.
* Global Saturation - Move mid line up or down
* Copy to other clips EDIT page right click copy the paste attributes Colour Correction (or)
* In timeline window in colour tab right click image and select GRAB STILL then go to GALLERY find clip you want to copy to and right click then APPLY GRADE
* White balance in first of colour wheels screen select eyedropper bottom left and click on neutral tone in timeline view window
* Colour Rainbow top right of Timeline view shows before and after
For smooth playback of timeline / transitions etc (Very important)
* Before you edit right click on clips in Media Pool and Select GENERATE OPTIMISED MEDIA
* In the PLAYBACK menu (Top) ensure USE OPTIMISED MEDIA IF AVAILABLE is selected
* ALSO Choose Playback/Proxy Mode/Half or Quarter for smoother playback to show effects if still having problems |
