Osmo Action Shutter Speed Issue on Auto mode?
2465 7 2020-2-7
marauderx
Hi,
after the recent firmware upgrade, I think I am seeing an issue with the shutter speed in auto mode: when setting any ISO max value different that 3200, starting to record and moving from a low lit area to a bright area and back, the minimum shutter speed (auto), seems to get stuck to 1/100 (from the original 1/30), which makes the exposure too dark in low light conditions.
Check video at:  https://www.youtube.com/watch?v=tkKvOthoND8&t=26s
This only seems to happen when recording, and does only get back to 1/30 when changing the ISO max value to something else, or power cycling the camera... but then again, when recording the issue appears again....
Can anybody try this and confirm if they are also seeing the issue?
2020-2-7
Fishycomics
2020-2-7
id4alexey
Russia
Fishycomics Posted at 2-7 08:33
Do you have RS mode ON? If yes - test with RS OFF, it may be connecting.
2020-2-7
marauderx
id4alexey Posted at 2-7 08:44
You are correct, I tried disabling RS, and the issue did not show up... but still, not happy about it... most of the time I'm filming while moving and keep RS on: I need (and would expect) the exposure in auto mode to work with RS enabled.
Do you know if rolling back to the previous firmware is possible?
2020-2-7
CemAygun
Flight distance : 810 ft
Philippines
marauderx Posted at 2-7 10:55
RS relies on high shutter speeds, this is also why it does not work properly with 180 degree fixed ss (1/60th of a second for 30fps etc.)...
2020-2-8
AdeyM
This is also a problem with colour set to D-Cinelike. In auto, the shutter selected does not go below 1/100. This is really annoying!
2020-8-15
Fishycomics
revert is like all the other things we wished for her, not possible
2020-8-15
relaxosmo
Flight distance : 180604 ft
Hungary
Thanks for the info.
Fortunately i have 1.08 fw which doesn't have this issue.
Too bad dji doesn't allow you to downgrade
2020-8-16
