Guorium
Flight distance : 513061 ft
InspektorGadjet Posted at 2-12 08:15
The transitional lift makes a lot of sense, I noticed than flying backwards doesn't happen so often?
Also if flying forward while ascending seem to be less noticeable... I tend to do this when you eye is in line with the mini and the mini only seems to decrease in size, like a straight line between your head and the drone. Is a technique I saw of some super experienced user flying backwards thru tight things or objects.
True. It should happen in any horizontal direction as the props leave the turbulent air. I haven't tried directions other than forward. Will try later |
