DJI GO 4 and Galaxy S9 Android 10 update
2776 12 2020-2-10
MicheleCaminati
Flight distance : 240266 ft
Hi everybody, how is it the actual compatibility with DJI Go 4 App and Android 10?
I've heard of many people running the App on Android 10 having troubles, and today my Galaxy S9 asks me if I want to update to Android 10 as well.
Now I fear of troubles after updating. I've got the latest version of DJI Go 4 App installed, and it has been working perfectly on my S9 (since I started connecting through the back USB port of the controller). Has anybody tried the update to Android 10 on the S9 or has any experience with DJI GO 4 on a device running Android 10?
Thanks for your help.
Michele.
2020-2-10
DJI Gamora
Hi, thank you for reaching out. We don't receive any incompatibility issues with regards to the Android 10 and DJI Go 4 application. We highly recommend only to update the DJI GO 4 app to the latest version to avoid any issues with your Android 10. Please don't hesitate to reach us if you have other inquiries or concerns. Thank you!
2020-2-10
MicheleCaminati
DJI Gamora Posted at 2-10 09:10
Good to know, thank you very much!
2020-2-11
DJI Gamora
MicheleCaminati Posted at 2-11 01:11
You are always welcome!
2020-2-13
djiuser_5RG1gr3lGqA8
Philippines
DJI Gamora Posted at 2-13 16:03
Hi Dji Gamora!
just had an update with phone last week...it previously run with Android 9 and my Dji go 4 app run smoothly in that version.. after the update i can't run my DJI GO 4, right after open it it immediately crashes. I've heard that there's an issue (after i update my phone) of running this app in android version 10.
Hope to hear from your end soon..
RealMe 5 Pro
Android Version 10
2020-3-14
Philippines
please answer...
2020-3-18
MicheleCaminati
I'm sorry to hear that, I made myself the update to Android 10 on galaxy s9 and dji go 4  App is still running smoothly. Have you tried to uninstall and install the latest version of the App?
2020-6-5
Skylge40
Hello, my name is Jan and I/m living in the Netherlands.
I also have problems to connect my Samsung Galaxy S9 ( with android version 10) to the RC.
In the app I choose : Connect to the aircraft.
I choose for the Wired connection.
But at step 3 it stops.
I have used three different RC cables,  but still no connection.
Before the S9 I used a S7, without problems.
At this moment I am using a Samsung TAB 8.0, also without troubles.
But I cann't get my S9 connected with the RC,  although I removed the DJI Go 4 app and installed a new one.
Please tell me what to do?
2020-8-11
MicheleCaminati
Sweden
Skylge40 Posted at 8-11 05:21
Have you tried using an USB type C cable through the bottom of the controller?
I had problems with small cables from the side, but when I switched to the bottom USB I never had a problem since. Not even after updating to version 10 of Android.
(I also enabled USB developer options in both application and phone)
2020-8-11
Skylge40
MicheleCaminati,
You asked me if I had tried using an USB type C cable through the bottom of the CT?
No, I did not, until now.
I used the cable that came with my Drone.
I was surprised. Now my S9 made contact with the CT and the DJI GO 4 app is working.
The cable that came to my Drone is about 60 cm long. So I ordered a shorter cable.
I'm happy that it is working now, but I still wondering why it wont't  work with that other connection to the CT on the side.
When I'm using my samsung tab a 8.0 ( also with android version 10 ) with the CT, there is no problem at all.
2020-8-12
MicheleCaminati
Don't really know, but I've read of a lot of people having problems with the side USB and I had problems as well the first time, so I went straight for the bottom USB and kept using that one.
2020-8-12
Grumbleduke
Flight distance : 1824862 ft
Hi all.  New user - first post.  I am flying a MM and have been using an iPhone 6 with DJI Fly software.  The screen is not quite big enough so I just picked up a Samsung Galaxy Tab A 8.0, which comes with Android 9 but is wanting to upgrade to Android 10.  I have installed the DJI Fly app and made a couple of short test flights and all seems fine.  Should I prevent the tablet from updating to Android 10 or will it be ok now?
2020-9-21
Grumbleduke
Grumbleduke Posted at 9-21 19:07
Update:  I let the OS update.  Have been flying the drone for a couple of months now.  No issues.  The Galaxy Tab A 8.0 just fits in the remote arms (looked like it wouldn't initially so I purchased an extra attachment - nice having the screen above the remote and a neck strap but a pain to install/remove every time.)
2020-12-6
