djiuser_u2HgaEkVHdEJ
Benin
DJI Mindy Posted at 2-11 19:40
Sorry for the difficulties you've experienced, how does it happen? Did you perform the firmware upgrade before the error occurs?It is recommended to connect to DJI Assistant 2 For Phantom and refresh the firmware. If the error persists, the drone will need to be sent back to the diagnosis.
Hi. Yes I did the last update of the phantom 4 with dji go 4. In fact I had a problem with updating the screen and I changed the card 3 in 1 of the drone. Now the update has worked fine but the problem is that the image comes and goes immediately. And I have the aircraft encoder error 0x800008. |
