fans6c392738
Flight distance : 1620945 ft
DJI Gamora Posted at 2-13 10:02
Hi, thank you for reaching out and we do apologize for the inconvenience. Can you please try to clean the vision sensor with a clean cloth to see if the problem persists? Also, a display that’s 14 inches or bigger is recommended for the calibration. Set the display’s resolution to the recommended default value. (Usually, the 14-inch display’s resolution should be set at 1366*768 or 1440*900. The 17-inch display’s resolution: 1366*768 or 1280*720. The 19-inch display’s resolution: 1366*768 or 1440*900. The 22-inch display’s resolution: 1680*1050 or 1920*1080. The 24-inch display’s resolution: 1920*1080 or 1920*1200). If the problem persists, kindly please restart the PC and aircraft multiple times. In addition, please make sure that you are using the latest version of the DJI Assistant 2 to avoid any errors. Please keep us posted. Thank you for your understanding and support!
Made sure to try both options with the 22" monitor settings, same results, cleaned the sensors , removed the blades and tried several times to no avail.
