Ronin noisy even at total idle
12
29462 55 2014-11-17
trftrf
Luxembourg
Also got the DJI RONIN.
Mine is making a permanent hissing noise. Can be heard across the room and easily picked up by microphone.
Canon eos 5d Mark II with 24-105 L Lens
System balanced well, no lose screws, lens support installed, motor stiffness under 20
Here's a video:
Is that hissing sound normal?
2015-3-26
trftrf
Luxembourg
So today I was told by my reseller, that apparently all the new RONINs make that hissing sound and that only the first generation didn't make that sound!
Could anyone confirm that statement?
2015-3-27
Amulet
Yes I can confirm too. European Support told me the same thing, that this noise was introduced with current builds. The noise you hear in your YouTube video is the same noise mine makes and that in the original posters YouTube video. I sent a video of mine to Euro Support who told me the noise is generated by the electronics in the stem where the battery attaches.
This morning I got another message from Euro Support who told me China have been made aware but they don't have an answer from them at this time. I've tried to follow up myself with HQ in China but nothing so far.
As this problem was first reported in November it would be useful if DJI could confirm if they intend to fix it and how that might happen.
2015-3-27
trf
Flight distance : 30308 ft
Luxembourg
@ Amulet: Thanks for the clarification
@DJI Support:  So how about it? Will you fix that Problem??
2015-4-4
alwyne
I started this thread. I eventually sent my Ronin back to the vendor for a refund. Three months later I bought a used one on ebay... and it makes the exact same noise. Cleary DJI have screwed up, releasing a batch of Ronins that are not fit for purpose in that they cannot be used on a sound set.
Does anyone know what the current situation is regarding DJI's declared intentions to rectify this issue?
2015-4-6
adamonline
My Ronin does the same - even with motors killed.
Its sometimes doesn't do it immediately after turning it on, but as soon as you move it - the noise starts.
It almost sounds like a small fan is running. Its coming from the main circuits infant of the battery, it is not coming from the motors.
Mine is perfectly balanced (0,0,0 motor power) and I'm running 10 for stiffness on my pan/tilt/roll as I'm using a DSLR (Nikon D750 with 14-24mm f/2.8 lens)
I won't be sending it back until a solution is found, I record externally so its not an issue for me...being gimbal-less is an issue though.
2015-4-7
adamonline
Here's my video showing it on and silent (just turned it on, motors are ON) until I touched it and made it rock on the stand - sound started and stays till unit is turned off
2015-4-7
trf
Luxembourg
I sent mine back to the vendor for a refund.
The noise was always picked up by microphone, cam internal which is normal but also on external rode ntg2 that was a few feet away.
It's a shame, because i liked the ronin gimbal a lot.
I hope they will fix the problem...so i can get a new one
2015-4-7
dmelhorn
I just received mine yesterday and had the horrible vibration and noise when the Ronin was properly balanced and set-up.  Ironically, it went away when "improperly balanced" by dropping the camera to its lowest point on the vertical axis.
The solution was to dial the "stiffness" back down to the 5-10 range.  Since then its worked fine with both a Canon C300 and Canon 5D.
Tomorrow I plan to put it through some paces before it begins working next week.
2015-4-16
jstecyk
Hello Alwyne did you figure out what the problem was, I am having the same problem with my 7D, camera is balanced, motors are at near 0 power but there is still slight motor noise, even when you kill motors
2015-5-28
micahmart
I have had the same problem with mine since I bought it 2 months ago, been trouble shooting for a while, it seemed like a bit more weight helped, but even when balanced perfectly that F%$kin humming noise was still there.  well I just plugged the Ronin in directly to my Macbook after I downloaded The DJI  Ronin Assistant Software v1.8 for Mac (http://www.dji.com/product/ronin/download) and updated both my GCU and IMU firmwares, and tried it from there.... well the noise was still happening, oh and I'm rocking a 5d mark ii with a nifty fifty lens on it so not very much weight at all... Anyway I figured I would try Silent Mode again (Be sure to update your Iphone or Android App as well so it has Silent Mode) it hadn't worked at all before the firmware update, but I'll be damned, I clicked the little bastard and all the noise came to an immediate stop and my Ronin works perfect and there is no noise at all....  Hope this helps, I am still amazed that that was all I had to do, I was sure the thing was faulty or something, but It seems to be working....
2015-8-9
Dio00
Mongolia
Same issue, first i thought it was bad balancing and made best balance in the world end up with NOISE. So i searched and found this thread lol. So there is no solutions rather than refund?
2018-8-22
wernerlich
Sweden
a bit late maybe.. I Had the same problem I think. The noise came after the last update. When I tried to update again (like hundred times) I always turned the gimbal off before taking out the usb cable. This time I took out the cable without turning it off and now the noise is 99% gone! If I put my ear to the motors I can still hear it really low but it's way way better now!
2018-12-6
alwyne
I solved my issue by discovering that the later version  firmware / app  I had installed had a "Silent Mode" option.  That was all it was - by default, Silent Mode was turned off. Once I discovered the option, I turned it on and the noise went away.
What I find strange is that no one at DJI suggested that to me.  It was the obvious thing to suggest.
2018-12-7
VinnyS
Hey guys, sorry to resurrect this thread. I bought my Ronin years ago and never used it for this particular reason. I took it out to shoot with my new Blackmagic Pocket 4K and had a slight noise issue. I decided to check to see for a new update and there was. After updating it, MASSIVE NOISE and vibration. After it being perfectly stable, it says to rebalance. I can't rebalance something that is perfectly balanced and now the unit is really unusable. I should have stuck with the original firmware as it was workable, now it's really not.
I'm so discouraged. I'll try the above fixes and post back for anyone else looking. Are people still using original Ronins on shoots or has everyone moved on to Ronin-M and/or other brands?
2019-4-9
Piotr Adamczyk
Poland
VinnyS Posted at 4-9 10:30
From what i see in the Dji assistant app you can downgrade, i had very similar issue, noise on idle position and right after turning the gimbal on, but i followed what DJI-擎天柱 wrote:
1. Balance Ronin in all 3 axis.
2. Tighten all knobs in Ronin.
3. Tighten camera securing screw and lens support.
4. Decrease the stiffness of each axis.
I did just the 4th point as the camera was perfectly balanced and all the noise went away. I would consider sticking with the latest updates, In the updated mobile app there's a nice 360 roll option without messing with motor settings.
2019-4-25
12
