JJB*
Flight distance : 12132231 ft
jonny007 Posted at 2-14 10:45
Isn't a slight increase after an abrupt stop normal? The drone is tilted, the propellers turn quickly, then there is a stop and the drone is immediately level, but the speed of the propellers is not yet as low as it is during hovering. Hence the slight increase. I think every lighter drone has such a behaviour, what would be logical for me. Or am I wrong with these thoughtness ? And close to water surface better disable the vps sensors. ;-)
Hi jonny,
yes, i think this is 'normal' behaviour for a MM, having said that my MA does a better job keeping height when quick stopping like i did on the video.
My test was done with a reason ofcourse, some MM does climb and drop afterwards. Few cases on this forum dropping after quickstop but happend flying low over water.
So what is the influence of VPS height is this....
Flying out of VPS height range only the baro sensor signal is used to keep height, with accelerometer signal ofcourse.
Within VPS range...VPS do have some effect on height keeping * . But how much and what if this signal is not as steady when flying over water?
* hover your craft at 50 meters height in Sport mode, full stick down and do not release stick!
See the craft slowing down when getting into VPS height range and does stop the descend at 0.5 meter....
cheers
JJB
