Canon EOS 200 D - How to connect to Ronin??
4377 6 2020-2-15
ourfrank34
Flight distance : 105430 ft
Hi there,
Can anybody tell me which  MULTI CAMERA CONTROL CABLE do I use to connect the Canon EOS 200D to the Ronin S ?
I have the MC control cable (Mini USB), however the socket is on the other side of the camera and the cable is not long enough. I do not have a IR option on this camera.
I would be very grateful if someone could assist!
Thanks
Warren
2020-2-15
ourfrank34
Surprised nobody has replied to this post (maybe it was a stupid question) but I've mastered it, not via YouTube as there is not a video out there! I have ordered a cable extension on Amazon for MCC USB mini cable and that should do the trick! Might help somebody else with same issue.
2020-2-16
Hi ourfrank34, we are so sory for the late response, MCC-Mini is the corresponding cable and it should work, please double verify whther you use the correct cable: https://store.dji.com/product/ronin-s-camera-control-cable-miniusb MCC-Mini cable.png
2020-2-24
Goldy1967
ourfrank34 I also have the 200D with the same problem cable too short. What extension cable did you buy. I tried to google extension cables for the MCC USB mini but still can't find anything.
2020-5-28
Goldy1967
DJI Mindy Posted at 2-24 02:52
Hi ourfrank34, we are so sory for the late response, MCC-Mini is the corresponding cable and it should work, please double verify whther you use the correct cable: https://store.dji.com/product/ronin-s-camera-control-cable-miniusb[view_image]
[view_image]
How many inches is the cable you just posted? I purchased one that measures 10 inches and it was too small.
2020-5-28
Goldy1967
ourfrank34 I think I may have found the extension cable. Here's what I found: Mini 5 Pin USB 2.0 Type B Male To Female Extension Charging Data Cable Lead 50cm
2020-5-28
ourfrank34
Yes, I ordered a USB 2.0 Type-B Female Male Left Angle Extension Cable/Lead (0.2 Metre) from Amazon and it has done the trick. It is a pity that the Ronin-S Multi-Camera Control Cable (Mini USB) is not longer and we could have avoided the cost of getting an extension adapter. It seems nobody thought about the usb plug would be on the other side of the Canon D200/Rebel 2
See link below to adapter
https://www.amazon.co.uk/gp/prod ... 0?ie=UTF8&psc=1
2020-5-30
