Mavic batteries
962 2 2020-2-18
steliosmad
Flight distance : 128376 ft
Greece
Hi
Can i store the batteries in the hub that it came with the fly more combo.
2020-2-18
steliosmad
Greece
For mavic mini i mean.
2020-2-18
DJI Stephen
Hello and good day steliosmad. Thank you for reaching out and for the inquiry. You can use the DJI Mavic Mini Charging Hub to store your DJI Mavic Mini Intelligent Flight Batteries. In addition, the DJI Mavic Mini battery does not have a days until automatic self-discharge setting. For a battery that will be kept idle for more than ten days, discharge it with the two-way charging hub, or insert it into the aircraft and power on the aircraft to discharge it until the battery level drops to 40-65% ( two to three battery level indicators light up ). In addition, the battery's performance will be influenced if it is kept idle for a long time. To maintain the battery's active state, it is recommended that users charge and discharge the battery every three months. Do not completely discharge the battery and then store it for a long time; otherwise, the battery will over-discharge and the battery cells will be damaged, which will make the battery unusable. Thank you.
2020-2-18
