Phantom 4 RTK won't connect
6974 7 2020-2-18
Joe_C
I just received our new Phantom 4 RTK and wanted to make sure the firmware is up to date and make sure everything works.  The controller powers on fine, connects to wifi but would not connect to the aircraft.  The aircraft would boot up and just sit there with all four lights staying red.  The controller said it needed a firmware update so I went ahead.  Maybe a mistake?  Anyway, still can't get the aircraft to connect.  I thought maybe the RTK needed to be powered on and that won't even connect to the controller.
I'm pretty new to the RTK version of the Phantom.  I got this for work so we could start doing some aerial surveys.  I have a personal Phantom 4 and Mavic Pro and never had problems connecting them to a controller.
Any and all suggestions are appreciated.  I tried to search the forum to see if there were similar issues but only for Mavics and Phantom 3.
We're still a few months out from being able to fly due to weather but wanted to make sure everything functions at least.
Joe
2020-2-18
m_s
Have you done the linking process already?
https://www.youtube.com/watch?v=jPdlE_zKWYk
2020-2-18
Nebuchadnezzar
Flight distance : 3428747 ft
2020-2-18
Nebuchadnezzar
hope it help !!
2020-2-18
Joe_C
That was a really good video on how to use the RTK function and planning the flights.  My problem is that when I turn on the controller and then turn on the aircraft they should connect I believe and they are not.  I got a reply from the vendor where I purchased it and their tech people are calling me this morning to go through it.  I'm sure I'm doing something wrong here as the RTK is completely different from my other Phantom 4 and my Mavics.
2020-2-19
Joe_C
m_s Posted at 2-18 22:40
Yep, this is an older video but I found the process on the new firmware.  When I pair the aircraft to the controller both the small side light that is the link button on the aircraft and the light on the controller both go green and the menu on the controller shows that it's linked with the aircraft.  However when you go to the flight control screen where you should see a camera image from the aircraft it shows aircraft disconnected.  Thanks for sharing the video though.
2020-2-19
djiuser_BIR6H034nFLV
Hello, we have exactly the same problem. Do you found any solution ? Thank you for your answer
2020-6-5
Joe_C
djiuser_BIR6H034nFLV Posted at 6-5 06:23
I ended up sending it back and getting a replacement.  I purchased through DroneNerds and they tried their best to help over the phone but in the end nothing worked.  They had me send it back and sent me a new one.  The new one works great now.
2020-6-5
