-Hellsing-
Flight distance : 175738 ft
Belarus
Matthew Dobrski Posted at 2-21 12:08
The original files are always imported from SD card to computer drive as they are. The system video player (Windows or Mac) may play them back correctly, but video editor may not. Make sure that project settings match original file parameters (frame size and speed, fps that is). Some editors (i.e. Adobe PP) are notorious for stuttered playback of 4K files thru the timeline. You may consider dealing with proxy files option. What are the output rendering parameters is up to you, but - assuming match with original files - the final product should play back without issue.
I think I understand the reason. I accelerated the video in adobe premiere by 125% and the original video was 2.7 k 30 frames per second. If I don't speed up the video, then everything is fine. To speed up the video it is better to shoot at 1080 60fps? |
