BobWinNV
Flight distance : 284209 ft
Sorry for your bother but I already had everything plus more with the link that I showed you.
You have wasted a lot of your and my time and have not added anything to the conversation except to answer yes the Mavic Mini Altitude in EXIF (both absolute (MSL) and relative (relative to launch point) are often way off.
Thanks again for trying but you really should can the attitude it doesn't sit well with folks and doesn't do anything good for your image.
Here is an example of what the program that I use for EXIF supplies.
ExifTool Version Number : 11.88
File Name : DJI_0591.JPG
File Size : 6.0 MB
File Modification Date/Time : 2020:02:19 16:50:19-08:00
File Access Date/Time : 2020:02:21 18:30:28-08:00
File Inode Change Date/Time : 2020:02:21 18:30:26-08:00
File Permissions : rwxrwxrwx
File Type : JPEG
File Type Extension : jpg
MIME Type : image/jpeg
Exif Byte Order : Little-endian (Intel, II)
Image Description : DCIM\100MEDIA\DJI_0591.JPG
Camera Model Name : FC7203
Orientation : Horizontal (normal)
X Resolution : 72
Y Resolution : 72
Resolution Unit : inches
Software : v02.43.0128
Modify Date : 2020:02:19 16:50:19
Y Cb Cr Positioning : Centered
Exposure Time : 1/640
F Number : 2.8
Exposure Program : Program AE
ISO : 100
Exif Version : 0230
Date/Time Original : 2020:02:19 16:50:19
Create Date : 2020:02:19 16:50:19
Components Configuration : -, Cr, Cb, Y
Compressed Bits Per Pixel : 3.93715
Shutter Speed Value : 1/640
Aperture Value : 2.8
Exposure Compensation : -1/3
Max Aperture Value : 2.8
Subject Distance : 0 m
Metering Mode : Spot
Light Source : Daylight
Flash : No flash function
Focal Length : 4.5 mm
Warning : [minor] Possibly incorrect maker notes offsets (fix by 1783?)
Make : DJI
Speed X : +0.00
Speed Y : +0.00
Speed Z : +0.00
Pitch : -2.50
Yaw : -113.00
Roll : -0.70
Camera Pitch : +20.00
Camera Yaw : +2.00
Camera Roll : +0.00
Flashpix Version : 0010
Color Space : sRGB
Exif Image Width : 4000
Exif Image Height : 3000
Interoperability Index : R98 - DCF basic file (sRGB)
Interoperability Version : 0100
Exposure Index : undef
File Source : Digital Camera
Scene Type : Directly photographed
Custom Rendered : Normal
Exposure Mode : Auto
White Balance : Auto
Digital Zoom Ratio : undef
Focal Length In 35mm Format : 24 mm
Scene Capture Type : Standard
Gain Control : None
Contrast : Normal
Saturation : Normal
Sharpness : Normal
Subject Distance Range : Unknown
Serial Number : 1SFLG8M0AK0728
GPS Version ID : 2.3.0.0
GPS Latitude Ref : North
GPS Longitude Ref : West
GPS Altitude Ref : Above Sea Level
XP Comment : Type=N, Mode=P, DE=None
XP Keywords : v02.43.0128;0.0.1;v1.0.0
Compression : JPEG (old-style)
Thumbnail Offset : 18432
Thumbnail Length : 10926
About : DJI Meta Data
Format : image/jpg
Absolute Altitude : +677.05
Relative Altitude : +31.10
Gimbal Roll Degree : +0.00
Gimbal Yaw Degree : +2.00
Gimbal Pitch Degree : +20.00
Flight Roll Degree : -0.70
Flight Yaw Degree : -113.00
Flight Pitch Degree : -2.50
Cam Reverse : 0
Gimbal Reverse : 0
Version : 7.0
Has Settings : False
Has Crop : False
Already Applied : False
MPF Version : 0010
Number Of Images : 2
MP Image Flags : Dependent child image
MP Image Format : JPEG
MP Image Type : Large Thumbnail (VGA equivalent)
MP Image Length : 380121
MP Image Start : 5943419
Dependent Image 1 Entry Number : 0
Dependent Image 2 Entry Number : 0
Image UID List : (Binary data 66 bytes, use -b option to extract)
Total Frames : 1
Image Width : 4000
Image Height : 3000
Encoding Process : Baseline DCT, Huffman coding
Bits Per Sample : 8
Color Components : 3
Y Cb Cr Sub Sampling : YCbCr4:2:2 (2 1)
Aperture : 2.8
Image Size : 4000x3000
Megapixels : 12.0
Scale Factor To 35 mm Equivalent: 5.3
Shutter Speed : 1/640
Thumbnail Image : (Binary data 10926 bytes, use -b option to extract)
GPS Altitude : 677 m Above Sea Level
GPS Latitude : 36 deg 18' 11.74" N
GPS Longitude : 115 deg 10' 28.37" W
Preview Image : (Binary data 380121 bytes, use -b option to extract)
Circle Of Confusion : 0.006 mm
Field Of View : 73.7 deg
Focal Length : 4.5 mm (35 mm equivalent: 24.0 mm)
GPS Position : 36 deg 18' 11.74" N, 115 deg 10' 28.37" W
Hyperfocal Distance : 1.28 m
Light Value : 12.3
