Balansing with Canon GX10
543 1 2020-2-25
Isanta66
Finland
I don´t manage. Seemś to be too big. unless one shop said that it should work
Have anybody succeed with GX10
Or is it possible to put two camera raiser plates, to get it a little higher.
Or extra weight somewhere on the camera
Every hint is welcome
Thank You
2020-2-25
After testing, the weight is less than 3.6KG, the camera width does not exceed 205 mm, and the height does not exceed 150 mm. The Ronin-S can normally provide stabilizing functions.
One Ronin-S could only mount one camera raiser plate. If the camera is too light, it is recommended to use the camera cage as an extra weight, but the compatibility still cannot be ensured. For better performance and experience, please use the camera in our compatibility list: https://dl.djicdn.com/downloads/ ... ibility_List_en.pdf
2020-3-14
