how can you tell if a dji phantom 4 pro vs phantom 4 pro v2?
7752 16 2020-2-26
PilotSmith
Flight distance : 706539 ft
I am looking to buy one used and how can I tell.
2020-2-26
DJI Gamora
Hi, thank you for reaching out. Can you please provide us the serial number through PM and I will inform you whether this would be a DJI Phantom 4 Pro or Phantom 4 Pro v2.0. Looking forward to your PM. Thank you for your support!
2020-2-26
PilotSmith
DJI Gamora Posted at 2-26 09:31
2020-2-26
Labroides
Flight distance : 9991457 ft
A faster and simpler way is to check the controller.
The original P4 pro controller is a GL300F or a GL300E for the + model.
The P4 pro V2 controller is a GL300L or GL300K for the + model.
2020-2-26
DJI Gamora
Thank you for giving us this information. Upon checking your serial number, it shows that it is a DJI Phantom 4 Pro. Hope this helps. Thank you for your valued support!
2020-2-27
fansfceeef84
Could you please check 07DJD9LOC10717
2021-10-17
G_Sig
Flight distance : 9109311 ft
Iceland
fansfceeef84 Posted at 10-17 15:46
Model: Phantom 4, build on: 20. September 2016
2021-10-18
JSV987
Flight distance : 7034 ft
Mexico
DJI Gamora Posted at 2020-2-26 09:31
Hi, could you please help me checking this number: 11UCF8R0A50070
Thanks
2022-11-17
DJI Gamora
JSV987 Posted at 11-17 16:28
Thanks
Hi, JSV987. Thank you for reaching out.  Upon checking your serial number, it shows that it is a DJI Phantom 4 pro+ V2.0. Hope this helps. Thank you for your valued support!
2022-11-18
JSV987
Mexico
DJI Gamora Posted at 11-18 07:25
Thanks you
2022-11-18
DJI Gamora
Hi, JSV987. You're welcome. Thanks again for your valued support. Have a safe flight always!
2022-11-20
djiuser_KewHFGl2Ir2C
Flight distance : 18153 ft
Bahamas
Please can someone help me decide what tyhe SN of my controller and aircraft are, there are so many #'s I can't figure out what is what,
2023-2-2
DJI Tony
djiuser_KewHFGl2Ir2C Posted at 2-2 15:58
[view_image]
[view_image]
Hi there. Thanks for reaching out. We sent you a PM for security purposes. Kindly check whenever you're available. Thank you.
2023-2-2
djiuser_BGBcNEiQljX1
07DDD21V100353
Hi can you help me check mind too please. Thank you so much.
Model WM330A
2023-7-11
DJI Paladin
Flight distance : 318 ft
djiuser_BGBcNEiQljX1 Posted at 7-11 11:54
07DDD21V100353
Model WM330A
Hi there. You can check your serial number activation date and other details using this link https://service.dji.com/active/search . Hope this helps. Thank you for your valued support.
2023-7-21
charles m
can you let me know what model 07DDD5D00A10743
2023-12-2
DJI Tony
charles m Posted at 12-2 12:29
Hi, Charles. This serial number does not show anything. Please make sure you have it correct. There might be some missed or incorrect characters. Once you get the correct serial number you can paste it here: https://repair.dji.com/device/search?lang=en&re=us to see the information. Thank you for your great support.
2023-12-2
