fans31104d30
Flight distance : 1014872 ft
Portugal
I'm using the P4RTK with and SDK controller and iPad. The problem is that, for some strange reason, the P4RTK does not produce a Survey folder with the necessary files for PPK. I had to buy an Android tablet and use DJi Pilot to be able to get the "Survey" folder. It would be so great if DJi could produce a unified app to use with a premium priced drone....In DJi Pilot, you must go to the last menu, search for RTK menu with the P4RTK connected to the radio (otherwise no RTK functions will appear) and chose the one with the DRTK2 Antenna. You must then pair the antenna with the radio and also pair the drone. The workflow is described in the manual. I hope that you will figure out the nedded steps.
