Cetacean
Flight distance : 2528264 ft
Aloha Mauro,
While I do not have a Mavic 2 Zoom, I have updated batteries with other DJI platforms. I do not recall ever having been notified that the battery needed an update, it was always that an update was required. Just knowing that the batteries needed to be updated helped me to figure out that I needed to switch batteries so they could all be updated. The update is fairly quick and then you can fly that battery.
Try doing another update with the problem battery and see if it updates. Also, you might want DJI Stephen to check your battery serial number. The warning indicated that you may not have an original DJI battery. By checking the serial number, Stephen can let you know quickly if you have an original DJI battery. If the battery is not an original DJI battery, you should replace it. Many have crashed with third party batteries.
BTW, flying with conflicting firmware series can lead to trouble. Being in the air when that happens can lead to a crash. Be sure to only fly batteries that are charged at over 90%, preferably 95%. At low charge levels, cell deviation can cause the motors to stop, especially in cold temperatures.
Hope this helps!
Aloha and Drone On! |
