OSMO Mobile 3 gimbal drift
7572 7 2020-3-1
Marl0we
Flight distance : 29393 ft
New Zealand
Hi DJI
brand new, First time use
The firmware is the latest version
Calibrated the gimbal
SO......
2020-3-1
Mesut
Turkey
I have same problem. I think all dji users have this problem. I think this is problem of firmware. Because gimbal is drifting when using normal camera app too. I hope they can fiz this.
2020-3-4
AlanHd
Flight distance : 797365 ft
I havent noticed thus on mine as i dont really leave it stood, (will have to check) but It would be nice if someone from DJI would provide official feedback on this. Like is this a known issue that is being worked on and will a fix be forthcoming or has the OP got a faulty unit that he should change,
2020-3-4
DJI Gamora
Hi, thank you for reaching out and we're sorry for the inconvenience caused. Can you please try to rebalance the gimbal and after balancing it again try to reformat it to see if the problem persists? I will be posting a video tutorial below for your reference. Please keep us posted on the said query. Thank you for your support!
2020-3-5
AlanHd
I’ve just double checked mine, at first I thought I was seeing the same issue but once the gimbal settles down after a few seconds it’s rock steady.
2020-3-5
djiuser_LRjSL23YC5mP
Belgium
Yes i have this problem also. And sometimes the camera swing in it looks like little tiktok dance.
2021-1-25
Diamondderp
I had the drifting issue too, but I watched the tutorial about how to balance again and after doing the steps I calibrated it. When it was done with calibrating it was still drifting and the focus was a bit glitching (maybe because I was pointing it at my computer screen). So I turned my screen off. Then it was still drifting, so I changed the position of my phone by using the joystick, then I reset the position (pressing two times on back trigger). It was then super steady.
2021-2-26
aronw95
India
This issue is mostly gone with the osmo mobile 4. Although, when I was using the OM3, I faced the drifiting on very rare occations, some calibrations fixed it.
2021-2-26
