guillermomeiner
Argentina
1) To link the controller with the drone you need to link just the way it says in the manual. If i am not wrong you don't have to open gs pro app (its a one time process), you go to the upper left corner, tap on device management (like a drone icon) and then you just follow the described on the manual. Its reaaaally easy, and again, it is done just for the first time, then it's just a "turn on and paired" method.
Paired or not you can work with planification process in Gs Pro, but not with the execution process. For that last part, obviously you need a linked aircraft.
2) Correct, a i dont know about any other apps which can run on the P4RTK controller (like dronedeploy for example). But, i have to say it, GS PRO is in VERY good level. Maybe some tools needed, or better maps (like google services)
3) Yes, regular phantom 4 is supported by many other app, like pix4d or dronedeploy. Not P4RTK case.
4) Yes my friend , an SDK controller should have a lot of apps working on it. Not P4RTK case. |
