DJI Stephen
Hello and good day Cryptic. The DJI Mavic Mini supports Smart RTH, and the aircraft can return to the Home Point automatically. Here are the logic, operation, process, and notices of the Smart RTH function.
Set a reasonable RTH altitude :
Before the flight, go to “Safety” and set the RTH altitude higher than that of the tallest building in the surrounding area. Users can set the RTH altitude from 15 m to the max flight altitude.
Logic of Smart RTH:
When the Home Point is recorded and the distance between the aircraft and Home Point is more than 20 meters, users can tap the icon shown on the left of DJI Fly to choose to land or initiate RTH. Press and hold the RTH button on DJI Fly, or press and hold the RTH button on the top left of the remote controller to initiate RTH. The remote controller will make beeping sounds(after the RTH triggered,can short press RTH button to stop the beeping sounds, the return will stop too.). When the GPS signal is strong, the aircraft will return to home.
Note: If the GPS signal is weak, the aircraft will hover ( if the GPS signal does not get stronger, the aircraft will hover for three seconds to prevent itself from drifting because of the poor GPS signal ), and then the aircraft will land. If the distance between the aircraft and Home Point is less than 20 meters, after users press the icon on the left of DJI Fly, only the landing option is available.
Smart RTH Process :
If the aircraft’s current altitude is lower than the RTH altitude that has been set before, then the aircraft will rise from its current altitude to the previously set RTH altitude ( when the aircraft is rising, users can pull the control stick to make the aircraft stop rising, and then the aircraft will return to the Home Point at the current altitude ). Then the aircraft will return to the Home Point along a straight line. If the aircraft’s current altitude is higher than the RTH altitude that was previously set, then the aircraft will return to the Home Point along a straight line at the current altitude ( the left and right control sticks ,yaw axis are controllable, the roll axis are not controllable ). After the aircraft returns to the position above the Home Point, it will land onto the ground automatically and stop the motors.
Note: Compared to other Mavic aircraft, the Mavic Mini’s aircraft rising logic during RTH has changed. The aircraft’s throttle control stick is still controllable when the aircraft is rising and its altitude is lower than 20 meters.
Notices for RTH and Stopping RTH :
Please always pay attention to the aircraft flight screen image and aircraft position during the RTH to make sure the aircraft is safe. If something goes wrong, users can press the “X” icon on the left of DJI Fly, or press the RTH button on the top left of the remote controller to cancel RTH. After the RTH is canceled, the aircraft will hover at its current position. In this case, you can control the aircraft manually. Please fly carefully and do not initiate RTH again until the aircraft is in a safe environment.
Thank you. |
