ikabor
Switzerland
DJI Stephen Posted at 3-10 12:02
Hello and good day José. Thank you for reaching out and for these information. The DJI Mavic Mini battery does not have a days until automatic self-discharge setting. For a battery that will be kept idle for more than ten days, discharge it with the two-way charging hub, or insert it into the aircraft and power on the aircraft to discharge it until the battery level drops to 40-65% ( two to three battery level indicators light up ). In addition, the battery's performance will be influenced if it is kept idle for a long time. To maintain the battery's active state, it is recommended that users charge and discharge the battery every three months. Do not completely discharge the battery and then store it for a long time; otherwise, the battery will over-discharge and the battery cells will be damaged, which will make the battery unusable. For reference I will post a link where in you can check the DJI Mavic Mini Disclaimer and Safety Guidelines ( https://dl.djicdn.com/downloads/Mavic_Mini/20191030/Mavic_Mini_Disclaimer_and_Safety_Guidelines_EK.pdf ). Thank you.
Bonjour DJI Stephen,
Encore merci...toujours très rapide et précis concernant vos réponse.
Très bonne journée.
José |
