ebswift
Flight distance : 10299 ft
Since I have 3 different popular cage types I thought I'd spend a few minutes comparing them using the Cynova adapter and my frankenrig microphone which is a pair of AKG C98's in a 3D printed enclosure attached to a Polaroid cold shoe mount. The polaroid mount works but I don't like the thumb screw arrangment. I 3D printed my own thumb screws but it still doesn't feel great, I'll revisit it one day but for now it works.
DJI Cage
Not much to say on this, it works if you buy a cold shoe mount adapter. I got the Ulanzi adapter and it's actually really good and cheap. So this is the cheapest option for a cold shoe adapter. The camera has to be removed to access the battery. Clearance around screen edges is adequate but it is still not easy to grab left, top and bottom screen edges for swiping.
PGYTech
This cage isn't very expensive, it has a cold shoe mount and a 1/4 mount on the side. The Cynova adapter fits in a similar fashion as per the DJI cage, I have no problem with the fitment. The camera has to be removed to access the battery. I actually find this cage a bit annoying to open up. The casing around the screen edges is deep and close to the screen edges which would make edge swipes difficult.
Smallrig
This cage is expensive but it is solid being made of aluminium. I didn't attach the front ring because it obscures the front screen (not that I use that screen much). If you don't want to use your front screen then attach the front ring to add a lot of protection to the front lens cover - in this case if you're using filters, use 52mm options that suit. The Cynova adapter fits into an in-set cutout in the cage although I wouldn't really call it any more of a solid fit than the other cages, it is slightly more protected from knocks. Make sure you buy the *new* Smallrig cage designed for the Cynova adapter, if you buy the original OA cage it will not fit the Cynova. The cage has a 1/4 mount on the side in a similar fashion to the PGYTech, it also has threaded mounting holes all over if you feel the need to deck out the little OA like a movie camera with lights or handles etc. One thing that sets this cage apart is you do not need to remove the camera to access the battery, there's no reason to remove it at all. In that respect this cage is more difficult to open than the other two if you lock down the thumb screws with an allen key. The cage has the cold shoe mount as part of the cage like the PGYTech. As for screen access, I'd say the Smallrig beats out the other two for access to the edges for swiping. It offers more room around all edges and is also bevelled at the inner edges so your finger gets to the edge easier. The cage is heavier if you're weight conscious.
That's it, I hope this helps your cage purchase decision. I bought the PGYTech because I knew at the time the Smallrig wouldn't fit the Cynova. But while the PGYTech was in the mail a forum member mentioned that Smallrig had the new adapter, that's the one that I really wanted so I ended up with both. I'll give the PGYTech to my niece, she recently bought an OA after looking at mine.
